Unit will not turn on - Heating & Cooling
    Master:
    Sergeant:
  • 388 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you still get nothing then it is a bad fuse or transformer.
Air Conditioning Delray Beach
Posted on Apr 12, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 39 Answers
Led lit? Could be a bad xfmr if nothing is turning on or a bad fuse on the board.
Posted on Apr 09, 2015
Wont turn on
On all Panasonic Toughbook Models,
if the unit will not turn on try the following:
Step 1: Unplug the unit.
Step 2: Take OUT the Battery Pack.
Step 3: Plug-in the unit.
Step 4: Turn On the unit.
The battery pack acts like a giant capacitor and can
prevent the unit to turn on, especially when the unit
was previously used on battery pack and was allowed
to fully discharge to below 5%.
When the unit is turned on WITHOUT a battery pack,
then a single Green light should show on the front
edge of the unit when the cover is open facing you.
When the unit is plugged in WITH a battery pack,
then you should see a yellow, orange or green light
which shows the battery is charging. When the unit is
turned back on, then you should see two (2) lights,
one green and the other yellow, orange or green.
If the unit is plugged back in and either with the battery
in or out you see no lights whatsoever, then chances are
that something is wrong with your AC Adapter/Power Supply.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Feb 18, 2014 | Panasonic Toughbook Computers & Internet
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
How to fix a black screen on a laptop
There could be one or more problems with your notebook, a black screen could be a system board problem. Does the power light come on? If so turn unit off and unplug it, remove the battery and plug the power supply into the unit. Turn unit on. If the unit turns on it is a battery problem. If it doesn't power on then turn unit off and reinstall the battery and turn the unit, if you unit has a vga port on the side hook a monitor up to it and see if you get output. If you don't it is probably a system board problem.
Nov 08, 2010 | Computers & Internet
AC condenser will not turn off after unit is turned off.
your contactor that supplies power to the compressor has its contacts welded together and even if you turn up the thermostat and the coil that holds the contacts closed will de-energize,but with the contacts welded together this is no longer possible,you need to replace the contactor
Apr 16, 2010 | Fedders A6Q10F2B Q Chassis Room Air...
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
Ac unit not turning on
Chances are your A/C unit can be repaired for a lot less than a new one -- I'd call for service.
May 07, 2009 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Unit turns on, then clicks off with a "protect" message
You have a bad speaker on this unit or the audio output circuit is in need of repair. Try to disconnect all of the speakers and then turn on the unit. If it still stays in protect, you will need to have this unit serviced, unless you understand how these solid state circuits work. If the unit does come on without the speakers, turn off the unit and add one speaker at a time until the unit will not turn on. Disconnect that speaker and have it checked out or have the wiring checked out. Good Luck
Jul 14, 2007 | JVC FS-G5 CD Shelf System
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
