I have a WA13V5 Diamond Drum Washing Machine.It has started to stop midway through the wash and only re-start when we move the washing a bit. What could the problem?how can it be fixed please.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Could b timer faulty
Posted on Apr 12, 2015
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 2976 Answers
    SOURCE: Washing Machine Moves in Spin Cycle
    There are 2 things you can do.
    All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
    There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
    Posted on Feb 02, 2009
    SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
    You probably did not save the mode you want. See the information booklet provided on how to set the mode.
    Posted on Oct 29, 2010
    SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
    maxx5, error F63
    Posted on Dec 14, 2010
    Samsung wa13v5
    The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
    Jan 19, 2014 | Washing Machines
    I have a maytag LSE7806AEE that stopped after filling the washing machine with water. I have tried everything to get it started but it will not respond.
    since you can get water going, power is ok. Once water is filled, it should start automatically. Sine the drum is not moving to wash the load, it is down to drum mechanism. BTW if you manually move the knob to spin what happens?
    Aug 06, 2013 | Washing Machines
    Washing machine
    check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
    May 18, 2013 | Washing Machines
    May 25, 2010 | Samsung Washing Machines
    Kenmore heavy duty 2 way tumble washing machine
    You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
    If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
    In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
    Jan 16, 2009 | Kenmore 44102 Front Load Washer
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Zanussi fj1254w washing machine
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    Rate me pl.....if helped.
    Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
    Washing Machines Logo
    50 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
