Boots; but screen display is garbage w erroneous flashes.
    Top Expert:
  • Computers & ... Master
  • 8,204 Answers
Have you tryed resetting your display settings?
its in your control panel.
Posted on Apr 13, 2015
2 Suggested Answers
  • 46 Answers
SOURCE: Garbage video on display on boot up
Sounds like your notebook video card is bad. It drives both the LCD panel and external displays. You'll need to replace it.
Posted on Mar 04, 2009
Black screen
Try downloading the photos to a computer. If this doesn't work there may be a problem with the flash chip. If so, try reformatting it - that worked for me when I had a couple of photo storage locations that constantly put up garbage displays and produced file error messages on downloading.
Jul 20, 2013 | Konica Minolta Dynax 5D / Maxxum 5D...
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Boot device not detect
Your PC is trying to boot from your external hard/flash drive.
You have to change the boot order in the bios. While booting what the screen, you'll see a message "Select F2 for boot or DEL/F10 for setup"
Go for the setup option, this will take you into the bios. Read the instructions carefully, you need to change to boot order, choose CD for 1, HDD0 for 2 anything you like for third. Press F10 to save and exit. Your
PC should now boot properly.
Or, as its just a flash drive, don't plug it in until your PC has booted.
Jul 24, 2010 | Seagate Free Agent Go Small 12 GB USB...
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Advent 9517 intermittent failier at startup and video problem
its either a problem with a memory "ram" or the graphic chip. changing the ram would solve it, if not a graphic chip can not be fixed.
Jul 20, 2009 | Computers & Internet
When I turn on my pc, it boots showing only garbage on the screen.
hi
After booting, the Operating system will only have Recylebin(garbage) as default icon. we need to put the other icons like my computer, my documents, mynetwork and others to desktop. you can do this by following steps.
Go to Run type "desk.cpl". Now you will get Display property window, there click on "Desktop " icon. After doing that you can see a "Customize desktop" button there. click on it. now you would able to see "My documents, My computer, my Network Places, Internet Explorer" beside all this icon will be able to see small square box. you need to click on the boxes. By clicking those boxes, you would get them on your desktop.
Apr 18, 2009 | Compaq Computers & Internet
Mar 03, 2009 | Toshiba Qosmio G35-AV650 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
