Question about Smart Car 2009 Smart Fortwo Passion
My car radio can be turned on when no key is in the ignition. How do I change this so that it only turns on when the ignition is in accessory mode?
  • 2,210 Answers
Is this a factory radio or an aftermarket radio?
Posted on Apr 08, 2015
  • David Hinterleiter
    David Hinterleiter Apr 08, 2015
    This is a factory radio.
  • rdjagger Apr 08, 2015
    I suspect a former owner retired it. Trace power wire from radio to power source. Remove from that power source which is always on and connect to accessory power source that is only on when in accessory run mode. Most likely at fuse block. Good luck.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Assuming your radio is aftermarket, and that the installer connected a power source directly to the battery and fused it, all you would need to do is 1) move the power wire/Constant to get power from the stock radio fuse block, or 2) wire it into the stock wires for the Power/Constant from the car.
2006 chevy impala radio & dash lights stay on now when ahut car off, key out and close and lock doors automatically. Never happened before. Help please..
Could be relay contact's stuck closed allowing power to stay on . Or it could be a BCM - body control module problem .
Retained Accessory Power (RAP)
The retained accessory power (RAP) system allows certain vehicle functions to operate for a specific amount of time after the ignition switch is turned OFF. The body control module (BCM) monitors the ignition switch position, battery condition, and each door ajar switch status to determine whether RAP should be initiated or terminated. RAP is controlled with two different methods; serial data and relay control. Some modules receive a RAP message from the BCM over the serial data circuits. Serial data controlled RAP is deactivated as required by their modules RAP power mode operation. Other subsystems are activated directly by the BCM through a RAP relay. Components and systems that are active in RAP are also activated anytime the ignition is any position other than OFF regardless of the door switch signals.
Relay Controlled RAP
The BCM keeps the RAP relay energized during all power modes, except Off-Awake and Crank. The relay is also energized for approximately 10 minutes after shutting the ignition OFF and removing the key, providing no door is opened.
Relay controlled RAP will end when one of the following conditions is met:
• The BCM receives an input from any door ajar or open switch indicating the opening of any door after the ignition key is out of the ignition.
Important: If the BCM is receiving any door ajar or open signal from those switches when the ignition key is turned OFF, RAP will not initiate.
• The BCM internal timer for the RAP expires after approximately 10 minutes.
• The BCM detects a decrease in battery capacity below a prescribed limit.
Systems powered by the RAP relay during the RAP power mode are as follows:
• A/T shift lock control solenoid assembly (w/ floor shifter)
• Power window circuit breaker
• RAP fuse
• Inside rearview mirror (DD6)
• Sunroof (CF5)
Serial Data Controlled RAP
RAP systems controlled by serial data are as follows:
Radio
Radio RAP activation/termination is the same as relay operation with 1 exception; the only door switch that will turn off the radio during RAP is the driver door open switch.
Vehicle Communication Interface Module (VCIM) (Onstar®)
VCIM RAP activation/termination is the same as radio operation with 1 exception; if there is an active call when the ignition key is turned off the VCIM will remain in RAP mode, and keep the radio in RAP mode until the call is terminated.
Do you know what a DTC - diagnostic trouble code is ?
DTC B1475 00: Retained Accessory Power Circuit
Your best bet , take it to a Chevy dealer !
Jan 31, 2017 | 2006 Chevrolet Impala
My key is stuck in the ignition.
Your car has several different ignition positions. They each offer slightly different functionality.
Off: In this position, the engine is off, and so are your electronic accessories (unless the delay has not expired yet). You can still turn on lights (headlights, interior lights, etc.).
ACC: This is the accessory position. Turn the key to ACC if you want to listen to the radio, play a CD or use other accessories without cranking the engine.
On: In this position, all of the electronics should come on. This is also the position that the key will return to after cranking the engine.
Start: Turn the key to this position to crank the engine. Let go of the key when the engine is running and the key will return to the on position.
http://www.aa1car.com/library/ignition_switch_positions.jpg
I use to own a car that had an ignition that was ACC - OFF - ON - START.
Try turning your ignition one position clockwise and see if the radio turns off and the key comes out.
https://hackadaycom.files.wordpress.com/2008/08/ignition.jpg?w=450&h=338
Jan 29, 2017 | Cars & Trucks
Why does it remain in accessory mode after the key has been removed from the ignition?
Some vehicles have an accessory delay function separate from the ignition switch. This delays turn off of the radio and interior lights until all occupants have vacated.
Jan 11, 2016 | 2004 Pontiac Grand Am
When turn key ignition off radio and clock stay on
Even when you remove the key from the lock?
Try to turn the key a little more to the left to be sure to move out of the Accessory position.
Hope this helps.
Feb 25, 2015 | 2004 Nissan Murano
When I turn off the ignition key the radio and dashlights stay on until it runs down the battery
sure your not turning key to accessory position ? but then key wouldn't come out. maybe ignition switch is the problem.
Jan 31, 2013 | 2004 Chevrolet Silverado 2500HD
Ignition lock accessory stuck on. car will not start
Did you replace the key switch or the ignition switch behind the key switch?
Aug 27, 2012 | 2002 Ford Taurus
Key locks in the ignition in the ACC position. can't take key out
when you turn key to acc pos that is telling the ignition to go into a accessory mode which runs the radio,wipers etc... but it doesnt allow the ignition circuit to run, and the key in most vehicles will not be able to come out,this is a security protection so that you do not leave accessories on that will drain the battery. The ignition key should only be able to be removed in the OFF position.
Jan 21, 2011 | 2001 Saturn L-Series
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
Smart Car 2009 Smart Fortwo Passion Logo
69 people viewed this question
Top Smart Car Computers & Internet Experts
David Payne
David Payne
Are you a Smart Car Computer and Internet Expert? Answer questions, earn points and help others
