Why does the handle get very very hot - Computers & Internet
  • David Kent
    David Kent Apr 08, 2015
    Hi Peter Bateman, I want to help you with your question, but I need more information from you. Can you please add details, like make (Company; ex. Dell)and Model number in the comment box?
    Master:
  • 301 Answers
It might be the battery you are referring to. some laptop do get very hot make sure that the fan are running
How To Diagnose and Fix an Overheating Laptop
Posted on Apr 08, 2015
    Habit-Forming:
  • 82 Answers
Handle? what is a handle in a laptop?
No shower hot water
does the handle rotate from cold to hot....if it does not seem to go all the way to hot it could have a set limiter under handle that has to be reset so handle will rotate to hot...pull handle and check the setting and see if that works...good luck...
Jul 31, 2012 | Dmm Symmons Temptrol II pressure balancing...
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
The hot and cold water handles both turn clockwise. Can I get the hot handle to turn counterclockwise so that you can turn both on by pulling the handles forward?
some manufacturers do that but if its new and you still have the box return it as faulty or get yourself a new cartridge for the hot hot is always on the left or should be
Dec 04, 2010 | Danze & Bannockburn™ Two Handle...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Handle gets to hot
you just open it and look for whats wrong in your iron.... or the handle in it is not compatable in the iron soo put some leather on the handle...
Jul 24, 2009 | Irons
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower not hot
There is a handle limit stop under the handle. Remove the handle with an allen wrench and you should see a plastic piece with a tab on it fit into the assembly. Remove it and rotate it slightly to allow more travel in the handle and reinsert. You will have to test it to see if it allows enough hot water to mix in. If it is still not warm enough repeat as needed. Once you have the water at a comfortable temperature reinstall the handle and enjoy.
Dec 31, 2008 | Plumbing
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
