Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
How to delete phone number - Vtech DECT 6.0 Cordless Phone with Digital Answering System
How exactly do you delete numbers on a cordless phone
Remove the battery over night & leave phone off Base stand if you want to delete ALL numbers (I'd unplug the phone line too to be sure in case your phone base has a memory chip, some do). To remove one or more numbers, Left click main button to bring up the phone list, bottom click to highlight the number you want to delete, click on SEL, then select Delete & press SEL again.
Jun 06, 2014 | Uniden 5.8GHz Cordless Phone
I cant delete phone numbers in my address book
Hi
To delete number, scroll to the number you want to delete, press the option button at the top left of your phone and scroll to delete. Press yes or select to the number.
Regards
Jun 22, 2011 | Cell Phones
How do I edit and delete numbers in my phones memory?
As you said me you want to delete some contact from you are phone memory means you can do this if you follow this things.Go to menu select contacts then scroll over to delete option and select that option after selecting that you will get two option telling delete all, one by one.If you select all contact will be deleted if you select one by one means you can delete one by one.If you want to edit the number means you can select menu and then contacts there you will get search select it and type the name after getting the contact select option then scroll over to edit number there you can edit.Thanks for you are question happy to help.
Jun 17, 2011 | Cell Phones
How to delete or edit phone numbers
Go to Phone book on your phone. It will display the Names List/Phone numbers you have saved.
Click on the number you want to edit/delete. Once the name/number is displayed, click on options and then Edit/Delete the Name/Number.
May 06, 2011 | Vacuums
How to delete phone number from call register
go to call logs.. then.. check out the number thats registered.. click options.. look for delete/erase.. delete all or delete one by one.. anyway.. whats the model of ur mobile phone? thanks
Feb 09, 2011 | Cell Phones
How do i delete numbers on my phone
hi,
go to contact menu
1.select delete option....
2. two options will be displayed(delete one by one or delete all)
if you want to delete one number give one by one or whole number means give delete all option
(or)
go to number which you want to delete select the option choose delete option..
this will definitely work
thanking u
happy new year
Jan 01, 2011 | Cell Phones
I need to delete specific number from my phone
yes
goto call history logs and select the number then select option on your phone then u will find delete.
u can do by this method
Jan 18, 2010 | Nokia N95 Cellular Phone
How to restore a deleted phone number?
by entering it back in the phone...they is no software to retrieve deleted number
Jun 29, 2008 | LG CU400 Cellular Phone
Retrieve a deleted phone number
If you delete the number in your phone phone book and you use SIM card then there is nothing to worry, just retrieve it from your SIM but if it is in your main phone memory then only one lucky way is check your recent call history to see the delete number is still there or check on call out numbers and received numbers. Only those areas which you may be able to retrieve. Good Luck
Apr 10, 2007 | Samsung SPH-a660/VI660
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
42 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
