Question about ASUS Google Nexus 7 Tablet
Why does it go into a sleep mode after max of 30 minutes can this be shut off
    Top Expert:
  • ASUS Master
  • 44,414 Answers
Yes it can you have put it power saver mode.
Posted on Apr 28, 2015
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Tablet keeps turning off while in use. Fully charged
Go into your settings and take it out of sleep or auto shut down mode.press the helpful button
Android Tablets Power Off and Sleep Options
Jan 26, 2016 | Visual Land Connect 9" Android Tablet...
My Kindle Fire HD won't turn off. I was watching a movie on Netflix and the picture just froze
Turning Off the Kindle
Quickly sliding the power switch on the Kindle enters and resumes sleep mode. If your Kindle enters a non-responsive state when sliding the power switch, you've likely entered sleep mode. Try sliding the power switch and holding it for four seconds to shut down the device. If it still does not shut off, you may need to reset the Kindle.
Resetting the Kindle
The power switch also serves to reset the device. Before resetting the device, disconnect it from any power sources, such as an AC outlet or your computer's USB connection. Sliding the power switch and holding it for 20 seconds forces the Kindle to reset and power down. However, a nearly depleted battery may prevent this action. If the Kindle still doesn't shut off, try charging it for several hours and resetting it again.
Mar 17, 2015 | Amazon Kindle Fire HD 8.9"
How to fix fujitsu t732 when it won't power on after sleep mode?
take the battery out and unplug it. Wait a minute and put it back, then try
Jul 04, 2014 | Fujitsu LifeBook T732 XBUY-T732-W7D-002...
My tablet which I purchased from Nomoreracks, turn off then it shuts down.
This is the sleep mode intended to conserve battery.
To change the setting, start from your tablet's home screen and follow these steps:
Settings > Display > Sleep > choose time
Support Troubleshooting Guide
Jul 02, 2014 | Kocaso Tablets & eReaders
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
TF700 WON'T TURN ON
There are a couple things to try.
Possible Problem: The tablet may have gone to sleep and a newly installed app or update is preventing the tablet from coming out of hibernation.
Solution: The tablet likely needs to re-start.
The trick is to know whether your tablet is in hibernation (actually running but not screen is turned off) or if it is actually turned off.
Scenario 1, tablet is on but is in hibernation mode
1. Press and hold the power button until you feel the vibrate. Then release. Wait 3 minutes (to make sure the tablet shuts down). After the 3 minutes go to scenario 2
Scenario 2, tablet is turned off.
1. Press and hold the power button. Keep pressing even after you feel the vibration (for about 30 seconds).
Other possible solutions:
If that does not work, then ...
2. Disconnect the tablet from the keyboard and press and hold (same as step 1 scenario 2).
3. If the others methods do not work, connect the tablet to a PC (with internet connection). Leave the tablet connected for a minimum of 30 minutes, but upto 2 hours. With the tablet connected to the PC, press and hold the power button (same as step 1 scenario 2).
If none of those worked, connect the tablet to a TV or monitor using the HDMI connection. If the TV/monitor displays the tablet, then use the display on the TV to reset to factory defaults and force a re-boot. While it is shutting down, disconnect from the TV.
If that does not work, check the user manual for how to reset the tablet to factory default settings.
Last but not least, contact Asus support because you might have to send it for service. But I suspect scenario 1 will work for you.
Feb 12, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Very frequently I get up on my Ipad the words "Slide to power off", in a further note is the word " cancel" Have I somehow done something in settings. Could someone explain for me please?
that is exactly what you are doing. All of the idevices have two power down options.
1) A quick press of the power button will put your device to sleep mode. This is like the sleep, hibernation, power save mode on your computer.
2) Long press of the power button will bring up the "SLIDE TO POWER OFF" option which will shut down your device. This option is for turning off your device completely. Its like rebooting your device.
Jan 10, 2014 | Apple iPad Tablets & eReaders
ASUS Google Nexus 7 Tablet Logo
48 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
