Question about Hoover Washing Machines
Hoover washing machine displayed either E30 or E03 error code. Can open machine but clothes are very wet???
    Genius:
  • Hoover Master
  • 1,585 Answers
Check pump 4 blockage
Posted on Apr 12, 2015
4 Suggested Answers
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: electrolux washing machine error code e30
    Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
    Posted on Jul 25, 2013
    Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
    Canon DLC: Article: Canon EOS Error Messages: An ...
    www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
    Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
    problems installing digital solution disk - Canon Community
    community.usa.canon.com/t5/PowerShot/problems-installing.../225
    How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
    Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
    I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
    Hoover dyn8144 and related machines
    Error code 03 followed sometimes by Error code 16
    Check the usual drain pump and resistance of heating element
    On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
    The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
    Jul 10, 2015 | Hoover Washing Machines
    Washing stops with error code E03
    CONTACT MANUFACTOR/ DESTRIBITER THEY CAN TELL YOU POST BRAND MODLE IN QUESTIONS PLEASE
    Aug 19, 2014 | Hoover Washing Machines
    Hoover dyn8164d had code E03 then E16 now E08
    Hi.
    These specific codes indicate the following:
    E08 means that the Motor jammed or tacho fault
    E16 means that the heating element is shorted or that there is a short in the circuit containing the element.
    E03 This error code indicates that the water is not draining quickly enough.
    Before doing anything it is worth removing the washing machine mains plug from the power outlet and leaving the machine disconnected for at least ten minutes. This will reset the codes if no faults still exist. Then plug the machine back in and select required wash routine. If all is well, well done you just needed to reset the machine. If a fault code is still showing then it would indicate there is still a problem in the area indicated.
    You said you had checked that the filter was ok, it is also worth checking that your drainage hose is not blocked or
    kinked.
    Jan 11, 2014 | Washing Machines
    Hoover Optima WMH 147 DF water keeps on filling up
    have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
    Dec 13, 2012 | Washing Machines
    Hoover washing machine showing H05 error
    Error code: h05 coming up when i switch on the tumble - Fixya
    www.fixya.com/support/t8443068-error_code_h05_coming
    Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
    I have a 3 month old Hoover washing machine [DYN10146P ...
    www.fixya.com > Forum > Washing Machines
    Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
    Hoover and Candy Washing Machine Error Codes - YouTube
    ? 5:00
    https://www.youtube.com/watch?v=kzhlvB2LjXg
    Sep 1, 2014 - Uploaded by eSpares
    Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
    Nov 18, 2012 | Washing Machines
    Error code E03 on washing machine
    Sep 28, 2009 | Washing Machines
    Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
    Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
    Nov 18, 2008 | Hoover AAA160 Front Load Washer
    Washing Machines Logo
    584 people viewed this question
    Top Hoover Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Johnny Ramirez
    Johnny Ramirez
    Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
