Where can I find firmware for this tablet?? And what is the name of program, that is used to wright that firmware?
Processor ATM 7023, touch screen ERF 282C
  • 1,602 Answers
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
Touch screen unresponsive
Have you tried re-loading the firmware?
See this page for your tablet. Support Firmware
Feb 12, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
Jan 15, 2014 | Supersonic 7" Touch Screen MID Tablet
Touch screen acts like it being touched without being touched
Might need a new touch screen. There\'s really no way around a faulty touchscreen, previous owner probably tapped it a lot
Nov 20, 2013 | Dell Latitude XT2 Tablet PC
Proscan Tablet
well its sounds like the problem starts from when you downloaded the stock firmware and it basically affecting the touch sensivity of the tablet ,and you send when you flashed it still the touch remain the same meaning it didnt work fully .so maybe you need to flash it again and restore factory settings
Jul 02, 2013 | Computers & Internet
Download firmware for m750b tablet
Be aware you need a working tablet to update. the program must be in working order and the processor must run. Once you start the upgrade, there is only a small routine running, to put the new program in the right place in the Flash memory. You don't get a second chance, if anything goes wrong, because even the routine to update can't be put in place or run.
An update is NEVER a solution for a bricked tablet.
Please check some forums what to do with your problem, but please don't brick the device with an update you can't get in place.
Dec 28, 2012 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
How to start may touch screen i am with ubuntu
You need to be running an OS that has touch screen enabled. http://forums.techguy.org/hardware/715186-enable-touch-screen-lenovo-x41.html
Dec 07, 2009 | IBM ThinkPad X41 Tablet PC
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
