Question about GE Microwave Ovens
How do I set my timer for 3 hours?? - GE Microwave Ovens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
You cant , you might can idk but you probably cant
Posted on Apr 09, 2015
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Want to change time on clock of Goodmans TCB20SG microwave
1. Hold the Timer/Clock button down for a few seconds till it beeps and shows 12/24 hours.2. Type the time into the display. Use the minute buttons to set the hour, and the second buttons to set the minutes. 3. Press the clock button again.
Apr 03, 2013 | Microwave Ovens
We do not have a owners manual and we just purchased the new LG Convention range LSB5682SW and we would like to know how to set the timer and the clock. I am not that savvy when it comes to th ese things...
You can get the manual here
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LSB5682SW&matchedModelCode=NOT_MATCHED&searchEngineModelCode=LSB5682SW&initialTab=documents&targetPage=support-product-profile#
SETTING THE CLOCK
The CLOCK pad is used to set the clock. The clock has been
preset at the factory for 12 hours operation. When the range
is first plugged in, or when the power supply to the range has
been interrupted, the timer in the display will show with
power failure "PF". You can make a choice between 12-hour
clock and 24-hour clock (refer to the page 28):
1. Press CLEAR/OFF pad.
2. Press CLOCK pad.
3. Press 1, 3, 0 pads to set the time if the time of day is 1:30 (whatever the time is choose the correct numbers)
4. Press START pad.
The clock will start.
CHANGING HOUR MODE ON
CLOCK(12hr, 24hr)
Your control is set to use a 12-hour clock. If you would
prefer to have a 24-hour time clock, follow the steps below
1. Press and hold COOK & WARM
pad for 3seconds. "OPt" will be
displayed.
2. Press "1" pad. The display will
show "CLO 12H"
3. Press "1" pad to switch between
the "12H" and "24H".
4. Press START pad to accept the
desired change
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Microwave Ovens
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jan 05, 2011 | Panasonic Microwave Ovens
How do I reset the Clock please?
What is the model? Typically, there is a button on the front of the oven that says: Timer. Touch the timer once and the hour and minute should come on. Set hour first and then minute. Hope this helps! M
Nov 09, 2009 | Microwave Ovens
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
I need an instruction manual
press both Hour and Min buttons simultaneously for two seconds. You will hear a beep and the timer will reset. Don't press any other buttons for twenty seconds. The display will now change from the time to the clock. Press the hour botton. The hour digit will blink. Use the Min button to set the hour. Once you have the right hour, press the Hour button again, and the minute digits will blink. Press the Min button to set the minutes. Once you have the correct time, press the hour button one last time and your time is now set.
Sep 16, 2009 | Microwave Ovens
I am trying to set the kitchen timer on my older spacemaker microwave for 2 hours and am unable to do so ... Am I trying to do something impossible?
The first step is to set the clock. To do this, push clock, set the time using the key pad and then PUSH clock a second time.
Once that is done you can set the timer by pushing timer, putting in the number of minutes you want and pushing start.
Jun 07, 2009 | GE Spacemaker Over-the-Range Microwave
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
