Question about JVC Televison & Video
The Remote for my JVC RM-C1821 tv has partially stopped working (the arrow buttons dont work as well as the guide & power button, however the volume/channel/numbers/a.v buttons do work) How do i fix?
  • JVC Master
  • 722 Answers
Hi David,
This kind of faults develop when the remote handset is dropped or it falls from a height. What happens is that the connection foil going to these keys breaks and as a result these buttons are cut off from the circuit. Hence is the problem. Considering the cost of the handset, you may buy a new one.
Posted on Apr 08, 2015
  • David Hayes
    David Hayes Apr 08, 2015
    I have 2 remotes for the same tv and both don't work correctly. Both with exactly the same buttons malfunctioning. ...
  • Sp Gupta Apr 08, 2015
    In that case the problem is inside your tv and you will have to consult someone who can handle your set.
  • JVC Master
  • 2,374 Answers
Did u already try new batteries?
  • David Hayes
    Yes I tried that already. I also have another remote which I bought when I thought I lost the 1st one and the exact same buttons don't work on that either.
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    NOTES:
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
I have a samsung tv i am trying to trying to program for this jvc remote. Could you give me some instructions?
Hi wnowens, to program your tv to that remote follow these 3 easy steps.
Samsung code = 12
1 Holding down TV/VIDEO, enter the code "1 2" by using the numeric buttons (0 - 9).Do not release TV/VIDEO. Keep holding it until the next step is completed.
2 Press STOP button while holding down TV/VIDEO.
3 Now try to operate your TV by pressing DVD POWER - TV POWER while holding SHIFT.
If your TV turns on or off, you have successfully set the control signal.
If you want a PDF copy of the user manual click HERE to download it.
Hope this helps enjoy : )
Feb 11, 2011 | JVC Rm-sxv521j Remote Control
What is the code for my hd 52786 jvc tv trying to program a dish network remote
Try these codes, the bold ones work the most often: 557, 558, 642, 559, 508, 649, 655, 667, 673, 676, 726, 735, 736, 737
If the codes don't work try the steps below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Feb 02, 2011 | JVC RM-C14G-1H Remote Control
My jvc telivision wen i plug in the tv it comes on and then cuts off i have no remote for it the remote is not working but there is ah light that comes on the tv next to the power button it says timer and...
The television is lock in timer mode. are there any buttons on the front panel where you can get into the menu. If, so go where it says timer and turn it off and see if that helps you.
Jul 14, 2010 | JVC RM-C18G-1H Remote Control
My tv its dont working whit dish network remote control
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jul 02, 2010 | Element Electronics FLX3210 32 in. LCD TV
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
Problem to program my remote control
Try using the guide to help you with this problemm if you dont have one, try going to a local store that sells this product.
Aug 24, 2008 | JVC RM-C18G-1H Remote Control
The JVC remote control, model JVC RM-SXVS60J, has stopped working as far as the bottom buttons go even though the top buttons work fine. If you can help, please.
Since the top buttons are working fine, i doubt that the remote is faulty. Sometimes its due to moisture/dust accumilating on the remotes board and creates a barrier against the board and the buttons. You may need to open the remote and clean the surface of the mainboard.
Hope this helps
JigSaw
Aug 04, 2008 | JVC AV-56WP74 56" Rear Projection...
Remote Codes
If you are willing to sell that remote I am interested please let me know. My dog ate mine. My email is dreamcharmer00@yahoo.com. Thanks and good luck!!
Aug 02, 2008 | JVC RM-C18G-1H Remote Control
Televison & Video Logo
80 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
