Question about VIZIO M701d A3R 70 Inch 1080p Smart
My Vizio TV has dark spot top left corner
My TV has dark spot on top left hand corner of screen. You can see the picture in the background but the colors are all darker. EX whites are yellows. It is the top 1/4 of the tv. Its like a big dark rectangle at the top of the tv. The colors are darker on the left side. As you get to the right, the colors improve to almost perfect but you can still see a faint line of dark.
  • Vizio Master
  • 722 Answers
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Posted on Apr 08, 2015
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a dark spot on my samsung full hd tv (not LEDtv)
You could possibly be dealing with a failing LCD panel. I've seen many of the dark spots in Samsung sets and it's due to defective LCD panel tabs. The only true fix is the replace the panel which would cost more than a new TV !!!
Sep 04, 2012 | Samsung LN-S3251D 32 in. LCD HDTV
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Elongated dark spot on LCD screen,speakers ringing
some units have replacable lamps for the backlight of the panel. take it top a qualified servicer.
Jan 23, 2009 | Televison & Video
Convergence problem
no u cannot do anything on ur own u need to call an expert,
Apr 04, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
VIZIO M701d A3R 70 Inch 1080p Smart Logo
1,653 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
