Question about Kenmore Elite Oasis 27052 Top Load Washer
It drains very slowly and it makes a high pitch sound when it does spin...sometimes you hear something tapping or slapping, likesomething is stuck.
    Problem Solver:
  • 11 Answers
To me it sounds like you have something stuck in your pump. I would check that first. I had the high pitched sound during the spin cycle on my machine and it turned out to be the drum bearings. That part used to be covered by a 10 year warranty but not anymore. My machine was less than ten years old and it cost me around 300.00 to fix it. I have paid for my machine 3 times over in repairs. My next washer will NOT be HE and probably an old school Speed Queen
Posted on Apr 08, 2015
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
During clothes washer spin cyle makes a high pitch squeeling sound like letting air out of a balloon very slowly
Thanks for choosing FixYa and welcome. You need to check the motor drive and spin bearing. It may be the bearing. The drive motor controls the spinning, draining, and the agitation. Usually, when noise is associated with the spin cycle, it is either one. It is not an easy fix. Make sure to follow your manual. If not, you may want to call out a professional.
May 02, 2011 | Kenmore Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
On boot up not reading the hard drive all the connections look good
How big is the drive? How old? You need a very quiet room for booting. When you boot, listen for a high pitched whine, this will be your disk spinning up. If you don't hear it, it may be stuck and a slight tap can sometimes make it spin again. Wishful thinking, but if it's older and small, break down and get a new big one. Don't throw the other away, the data can be retrieved. You can also go to bios and set boot for CD/DVD. Put in your master disk and you can get at your disk, maybe.
Nov 14, 2009 | Dell OptiPlex GX270 PC Desktop
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
High pitch continuous sound during washing cycle. not during fill or drain
Probably have something stuck in the chopper blade. You can try to dismantle the pump and clean out the obstruction, from the inside. But sometimes it will eventually work itself out. So try and run few more cycles.
Apr 26, 2008 | Dishwashers
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore automatice washe3r 12202
You could have a machine that has a siezed drain pump. this can be checked by removing the belt off of the bottom of the machine and spinning the drain pulley by hand. it should turn freely in both directions. if it does then the problem is in the main tub assembly. it could be a simple as a foreign object between the tubs or something more complex like a siezed transmission.
Mar 10, 2007 | Kenmore 12502 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
79 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
