Question about Refrigerators
WHY DOES TOP ICEMAKER FAN KEEP FREEZING - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Posted on Apr 09, 2015
My beko ap930 fridge freezerhas stopped freezing on top two freezer shelves and there is no reading on the fridge or freezer temperature indicator also sometimes the high temperature error warning...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Oct 04, 2011 | Refrigerators
Maytag RTD2100AAL freezer floor cold but not top shelves. refridge is forming ice on top
EASY JOB.
Leo Ponder
imufo2
Sep 30, 2011 | Refrigerators
My refrigerator is freezing everything on the bottom half but not the top shelf. HELP!!
EASY JOB.
Leo Ponder
imufo2
Sep 19, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
I have a Kenmore Ref mdl#106.64259400 the coils are working in the freezer area.the fridge area is not cooling and the front of the freezer is not freezing. the motor evaporator fan(above the coils) is not...
EASY JOB.
Leo Ponder
imufo2
Sep 14, 2011 | Kenmore 64234 Top Freezer Refrigerator
Evap fan not working
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
EASY JOB.
If
you need more help go here:
Leo Ponder
imufo2
Aug 21, 2011 | Kenmore Top Freezer Refrigerator
Freezer fan does not come on . Thought that replacing the DC motor would "fix" the problem. It did not. The compressor works as the freezer gets cold, but the fan never works so the refrigerator side does...
You have a bad main control board . The board in back of the refrigerator , behind an 8"X10" panel . Keep your old motor to play with . A small 9 volt battery will run it . I may have found 1 bad dc freezer fan motor in all the time i've worked on the new style G E refrig.
Aug 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My u line icemaker was freezing water but my iemaker was not working. I just installed a used icemaker, now the compressor and fan work, but no cool. compresor conections dont show leaks, compressor gets...
If the compressor and fan are both running and no cool then you have a sealed system issue. If you just replaced the icemaker assembly and it freezes but doesnt dump then you might have the wrong icemaker or a bad thermostat.
Jul 15, 2009 | U-Line Icemaker
Fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
May 25, 2009 | KitchenAid KSRS25ILSS Side by Side...
Makes ice for three days, water drips to fan, freezing up,
there is a device like a switch that makes the icemaker stops the solenoid valve of the water intake, u should check that switch...
Mar 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
