Question about Miele T8003 Dryer
How do I remove the front panel. Have an object crammed underneath the unit.
What would cause my kenmore elite oasis he won't restart after a LD code
Pump jammed or bad. Tilt machine forward. Remove back panel drain pump is located when facing front of machine on back right hand side. Unplug power wire,3 5/16 screws hold pump in place, remove, unclamp both hoses and remove pump. Remove any objects, check and make sure housing isn't cracked as coins sometimes make it into pump and can crack housing. If objects found and remove, reinstall pump, it should work. WHEN REMOVING PUMP PLACE BUCKET UNDERNEATH TO CATCH ANY WATER
Aug 30, 2014 | Washing Machines
Code out F 21 flashing
F21 aka SD is a Long (slow) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line.
You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out.
Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Also, could check this video as reference guide...
Keep us updated about your advance steps.
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I access the drain pump filter and check for foreign objects and/or debris
On the bottom front panel there are about three screws. Remove them.Then you will have direct access to the drain filter.Twist open drain filter slowly, water will come out so put a heavy duty garbage bag underneath to catch water
Dec 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dial gets stuck near the rinse cycle. How can I remove the front panel to check and lube
Remove the two screws in the back of the unit that stick out like a hinge attached to the top cover. You can use a square bit or #2 philips driver. Remove the top cover by moving it forward than lifting up. This will give you access to the front panel and control unit. However, your problem could be the unit is unable to drain which will cause the control knob not to advance. Make sure your drain hose is not restricted and it has a U shape in the drain hose so it has a siphon action. Also make sure the pump located at the bottom of the unit accessible from removing the front lower panel is functioning or does not have a foreign object restriction the impeller.
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
What is code F 02
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(Actual drain filter location and procedure below)
• If the above does not correct the problem replace the pump
How to Check your drain pump filter for foreign objects:
Most likely, this issue will be the cause of a clogged drain filter. Use my procedure below to help locate and clean this filter.
First, you will need to unplug your unit and shut off the rear water faucets that feed the unit.The pump has a clean out filter located at the front, behind the lower section of the front panel, that allows for the removal of large objects that may have passed from the basket. You will need to remove the front panel to access this large object filter device. Now, Once you have located the drain filter cap; Push twits and pull out the filter cap that is visible. Clear out any debris and wipe the filter and the surrounding area with a mild detergent. If needed, wear gloves and use vinegar or bleach to remove odors, mold and mildew. Rinse the parts completely, if possible. Next; Remove the drain hose and clean it with a mild detergent or warm water. If necessary, again use vinegar or bleach to remove odors and mildew. Completely purge this hose. Once the drain hose has been purged, Reconnect the drain hose and filter. Next; Place the front panel back on the unit. Reconnect the inlet hoses and plug in the unit and turn it back on for a test run. If the cleansing dose not produce positive results, replace the drain pump.
Click here to access service manual for your unit. The actual component access procedures dealing with this issue will be on page 3-10 in the manual provided under the title"PUMP MOTOR". Front door and panel removal procedures are also described in this manual. This will start on page 4-1. Foucuse on pages 4-3 and 4-4 for front panel removal to access the drain pump and filter assembly.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
If there is an object in the pump, preventing washer from spinning, how do I remove it myself???
Remove front panel under door.Lift unit up approx 45 degrees.Use some kind of support to hold unit in this position.When checking pump,do not to look for restriction in hoses
Nov 01, 2009 | General Electric WSSH300G Front Load...
Whirpool duet washer has F02 error code when I cancel the door is still locked. I tried letting it sit for a while and then running drain/spin but got SUD error code, when I push cancel button washer...
You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Jul 02, 2008 | Whirlpool Washing Machines
I keep getting message on my washer F-21 what does that mean?
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Jul 01, 2008 | Whirlpool Washing Machines
Filter
You will need to tip it back and remove the sump hose from underneath. make sure you unplug first.
Feb 24, 2008 | Hotpoint WMA66 Front Load Washer
Miele T8003 Dryer Logo
69 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
