I would like to know if i can get a replacement battery charger cord
    Master:
  • 301 Answers
Www.cyberguys.com
Posted on Apr 08, 2015
    Top Expert:
  • Computers & ... Master
  • 8,376 Answers
You might get one on ebay
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
Gps 1412 will not charge
Have you check the voltage output on your power/charger cord? It's easy to test if you know how to use a multi-tester or take it to a small electronics shop like a Radio Shack.
If there is no voltage output from the charger, then simply replace the cord. I have found that those charging cords can break real easily but it's hard to physically see any damage.
Otherwise, if you've already tried a new charger, you may need to send your GPS in for service.
Mar 31, 2012 | Magellan RoadMate 1412 Car GPS Receiver
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Its a metro and it purple
Check the charger for output voltage.
2. Clean the charger contacts in the phone with a q-tip and a little rubbing alcohol.
3.Check the cord on your charger for cuts, breaks etc.
4. If it's a car charger, check the outlet in the car for voltage, check the cord's fuse in the handle,
5. Check the battery-to-phone contact connections for cleanliness, tarnish,
6. replace battery with new.
Let me know how you do...
Jul 03, 2009 | Pantech Matrix Cell Phone
My phone wont charge.
start with the basics:
1. Check the charger for output voltage.
k
Jun 18, 2009 | Pantech Matrix Cell Phone
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Need a power cord for the charger
Try Casio Customer support. But I would imaging it will be a new charger. Is it a special charger? Would not an ordinary charger do?
Jul 19, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Computers & Internet Logo
David Payne
David Payne
