Question about Beko Washing Machines
My Beko wmb71442w washing machine is starting up but then stopping, it shows 2 minutes on control panel but I doubt it has even done that....help appreciated
    Genius:
  • Beko Master
  • 1,585 Answers
Try unpluging 4 10mins
Posted on Apr 13, 2015
catriver
  • 878 Answers
SOURCE: Maytag MAH5500B - shows Lr on screen and stops
shy, Lr is the error for a locked rotor. The machine is trying to run the motor but is unable. Usually this the motor control board that is at fault. The first thing to do is make sure the belt is on. After that some tests are have to be made to determine what is going on. Im going to lay out some instructions in case you want to get into this thing. You will have to remove the door by removing the screws holding the hinges on. Same thing for the spacers on the other side. Lift up and remove the door. Pull the front panel forward and lift off. Once the panel is off, set the door back on and close it. Unplug the washer. On the motor control board, bottom right, pull the JP4 harness connector from the board. Plug the washer back in and make sure the door is closed. Press delicates and heavy soil 3 seconds to activate the service mode. Now press the rinse key. Make sure the door is locked by pressing the max extract key. Now press the stain cycle to start motor control test. The motor should run rotating the drum at 50rpms. If the motor doesn't run, check for voltage at the 3 wire harness, MN4, should be 120V. If you don't have the voltage, problem is in the main board. If you have that voltage, then the problem lies either in the motor control, or motor itslelf. On the motor harness, 7 pin connector on the board (middle). Between the brown, white and black wires should all read 6 to 7.5 ohms. Between the 2 grays 150 to 195 ohms. If that checks, then it's the board. If it doesn't check, it's the motor. Ohm checks should be done with the power off. Catriver.
Posted on Jun 10, 2007
watugot
  • 290 Answers
SOURCE: Washing machine defaults to clean washer option
Sounds like user interface board. Try unplugging the machine, press power button for 3 seconds, plug machine back in and try again. If this does help, it will probably be a temporary fix. The user interface board is the one mounted directly to the console.
Posted on Sep 25, 2007
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
SOURCE: Beko A+A Class 1000 rpm
i would check the lint trap for foriegn bodies, e.g hairclips, hair bands, screws etc as these can cause the pump to stop working, be aware that water will immediately come out of the trap when you loosen it, good luck
Posted on Feb 23, 2011
  • 66 Answers
SOURCE: beko wme8227 stuck half way through cycle
Ring ds suplies 01782-625551 and ask for chell
Posted on Aug 16, 2012
Beko WMB714422 .... washing cycle stops after 5 mins of the cycle and shows 'end'. Cant get it to do a full cycle. Any ideas ?
This is most likely an issue with the motor, causing confusion to the electronics, sometimes you can replace the motor and remedy the issue but I have had a couple of occasions with Beko machines where the motor fault caused damage to the control board
Jun 12, 2016 | Beko Washing Machines
I have a beko wmb71442w. Lots of lint on clothes, how can I clean the lint filter?? Please help
check out the manual for maintenance information.
clean the rubber bellows behind the door as dirt can accumulate here
May 17, 2016 | Beko Washing Machines
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
Beko WMB71442w i have recently moved house and my
you need to take your drain hose off at the exit end it sounds like this end under has a bung in it so remove it ???
Nov 03, 2013 | Frigidaire ATF6000ES Front Load Washer
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
Washing Machines Logo
63 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
