Question about BT Freestyle 750 Digital Cordless Handsets
Phone rings but line goes dead it will not dial out
Caller gets engaged signal. I get no dial tone, dial number is dead / does not ring.
take the phone to a friends/neighbours and plug in to test for a dial tone
if no tone , have the phone fixed
if there is a dial tone call the service provider and ask for a repair to your line
Oct 18, 2017 | Lands Phones
Bought synergy 6500 twin units in March 2013. They have been brilliant to stop nuisance calls. However, they have suddenly stopped ringing. I can dial out with no problem but people calling me, hear the...
This type of consumer device has no more than a 1 year warranty and most are only 90 days. You best choice here is just to replace it as the problem is most likely the base station is defective.
Jun 29, 2017 | Lands Phones
Line one wont ring
Call a tech in, name change will not harm a line period.
Oct 09, 2012 | NorStar T7316E Corded Phone
We have an old toshiba phone system and our phone sevice told us we have a routing problem. We have 3 lines and the only number that rings now is our 3nd rollover line. It does not go to out main number...
Phone service? You probably have a Strata VI box in the back, but the pilot number and all of the hunting is part of the dial tone provider's equipment. Somewhere on the side of the box, you should be able to unplug all outside lines and plug single line phones or test the lines with no equipment on them. If the first line rolls to line 3 all by itself, then call the dial tone provider and have them test the group. You have to make sure you're not shorting out the lines. In fact, if you can get dial tone on lines 1 2 and 3, then it tends to make it their problem and not your Toshiba system.
Carl
Sep 14, 2010 | Toshiba Lands Phones
Dialing out
it's not sending a signal to the phone service check your phone lines for proper connection
Jun 22, 2009 | Vtech CS5121 Cordless Phone
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
No dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Feb 21, 2008 | Uniden Cordless Phone
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
BT Freestyle 750 Digital Cordless Handsets Logo
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
ptpumpman
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
