Question about Kenmore 30" Freestanding Electric Range Model 9230
Why can I not raise oven temp above 287 degrees?
Oven and controls appear to work as they should, but when I try to set oven temp it will not move beyond 287 degrees.
  • 231 Answers
SOURCE: kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Posted on Dec 18, 2007
docjohn174
  • 943 Answers
SOURCE: kenmore elite range oven problems
hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Posted on Sep 30, 2008
aborcass
  • 2651 Answers
SOURCE: low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Posted on Oct 21, 2008
philbran
  • 242 Answers
SOURCE: Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Posted on Dec 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore builtin oven model 911 4742990
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Why my oven temp only foes to 287 degree
have a electrical technician check it out
if it is a two element oven the it is possible that one element is not working or
the thermostat is faulty and not registering the higher temperature to switch the second element on
Nov 08, 2015 | Kenmore Kitchen Ranges
I cooked something for 40min as it said and at the end it was raw, I had to pur it on further 40 min this is a conventional oven
It could be your oven isn't as hot as you set it. Get a thermometer and check it. It could be the "something" you cooked was larger than the recipe was expecting... It's cooking, you have to adjust. It could even be your altitude above sea level. Higher, water boils at a lower temp, things take longer to cook.
May 15, 2015 | Ovens
Oven control won't let me raise temp. above 287, is there a way to reset control panel
Yes, you are in Centigrade (Celsius) mode. Check your owner's manual for instructions on how to switch between Centigrade and Fahrenheit.
Sep 09, 2014 | Kitchen Ranges
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Oven not heating up
Problem with oven sensor or control board (ERC). Oven sensor at room temperature should have resistance about 1080 Ohms, and it rises with temp rise.
Nov 26, 2009 | Kitchen Ranges
Oven cooks 10 degrees cooler. How can I fix it?
select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Jul 14, 2009 | Maytag MER5775Q Electric Kitchen Range
Soultion not viable
Any other posts have been blocked, so I don't know what you have been told or tried. Has the oven temp been OK until just recently? The range has not been moved or converted Nat gas to LP etc. recently? If yes to Q1 and no to Q2, I'd replace the oven sensor ( WB21X5301) and then reset control to +- 00. Sensor is the pencil shaped thing sticking out the back of the oven. Note: Your temp test method is not accurate enough to calibrate oven exactly. I take average temp after a minimum 3 on / off cycles using a digital calibrating oven thermometer to get them within 10 degrees of set temp.
Sep 01, 2008 | Hotpoint RGB745 Gas Kitchen Range
Pilot light out/will not go above 350
Sounds like the thermostat controlling the gas valve in the oven is not working, I’m trying to find if the oven igniter is electric, but believe the igniter is electric. If it does light then not regulate the temp above 350 degrees, I am convinced the thermostat control is bad.
Oct 23, 2007 | Magic Chef CGR3725 Gas Kitchen Range
Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 30" Freestanding Electric Range Model 9230 Logo
94 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
