Question about Dell Black Inspiron N5040 15.6" 3gb 320gb Wifi Cam Core I3 Win7 1yr Warranty
My Dell Inspiron n5040 freezes on Windows logo and when I try to install Windows still the same. How do I fix?
  • 3 Answers
SOURCE: blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
Posted on Apr 14, 2010
Geekman
  • 32281 Answers
SOURCE: I have a dell Inspiron n5040 and it's not even a
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Posted on Apr 10, 2012
atang1
  • 734 Answers
SOURCE: Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Posted on Apr 14, 2012
  • 144 Answers
SOURCE: dell inspiron n5040 makes seven beeps and then shuts
error beeps at start up are hardware faults.
Posted on Apr 17, 2012
Geekman
  • 32281 Answers
SOURCE: password won't work on Dell inspiron n5040
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
Posted on Jun 19, 2012
Hello i have my laptop dell n5040 xp win installed also dowload idt high defenition audio but still audio sound not working what did to install i dont understand. please help
Completely remove whatever sound drivers you do have installed, restart, download this: http://ftp.dell.com/audio/R302718.exe
Once downloaded install the sound driver I have provided the link for. If it still doesn't work, please post back here with your DELL service tag. This can usually be found on one of the labels on the underside of the laptop. I may be able to help further if you can provide that information.
Mar 25, 2014 | Dell Inspiron N5040 Black New
Inspiron n5040 will not pull up any websites
Inspiron N5040 requires either a Wireless-N router (for Wireless-N Wi-Fi (802.11b/g/n)) or a Fast Ethernet (10/100) connection.
Assuming that you can connect to the internet (i.e., your router and your ISP connection is okay), you may download the latest drivers for your OS from Download free driver for notebook Dell Inspiron N5040 Windows 7 XP Vista . Hope this helps.
Feb 19, 2014 | Computers & Internet
My Dell N5040 has no power. When you hook charger up the light goes out on the charger box.
have you try without battery in? in case check the voltage of the power adapter with a multimeter.
Oct 28, 2013 | Dell Inspiron N5040 Black New
I have a Dell N5040 that has no power. When you plug charger in the light on the charger box goes out. Any help would be appreciated.
this is problem with mother board
try this
remove all power connections
remove battery
press and hold power button for 30-40 seconds
and just plug power connector with out battery
if it power on go to bios and restore defalts
try to are three times
or chaing mother board
I have a inspiron N5040 with windows 7 When I turn on it goes to windows recovery screen. I followed the repair(recommened) it will eventually bring up a blue screen with a cursor but no way to log in. I...
Try installing on top of its self. It may create another directory and rename the original Window (old). This however will cause you to lose your settings like installed apps and documents. They will be in the OLD folder, but not readily accessible on the new install.
Jun 10, 2013 | Dell Inspiron N5040 Black New
Dell N5040 touchpad
Is there the option to uninstall? If so, try this, although it may only be a temporary fix because if you're using windows 7, it will automatically detect and install upon restart, although you may disable the automatic installation in CP
Aug 07, 2012 | Dell Inspiron N5040 Black New
Dell inspiron n5040 manual
Look for it on ebay then cause that's about the only place that might have a copy of the manual. But your chance of finding one is still slim to none.
Jul 23, 2012 | Dell Latitude E6500 Laptop
Apr 13, 2012 | Dell Inspiron Computers & Internet
My dell inspiron freezes on the welcome page
While there are a number of possible solutions which may or may not work depending on several factors, the easiest to try is to boot to safe mode and run a system restore.
To boot to safe mode:
When you start the system, as soon as the blue dell logo goes away, tap the f8 button. This should get you to a menu from which you can choose "safe mode". It will show a bunch of writing on the screen and should eventually bring you to the login page, login as administrator.
Run system restore:
This varies depending on which version of windows you are running. In XP it is start>all programs>accessories>system tools>system restore.
Other things you can try:
Login as a different user.
Use start>run>msconfig from safe mode to disable startup items which may be causing the problem.
Consider removing recently installed software which may have caused the problem.
Scan for viruses, malware, spyware, ect.
Run diagnostics on the system by pressing f12 on the dell logo and chosing diagnostics.
The worst case scenario to fix a problem like this is reinstalling windows.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
Dell Black Inspiron N5040 15.6" 3gb 320gb Wifi Cam Core I3 Win7 1yr Warranty Logo
55 people viewed this question
Top Dell Video Cameras Experts
Are you a Dell Video Camera Expert? Answer questions, earn points and help others
