Bosche washing machine no spin
The machine seems to click through the cycles perfectly and the pump and water inlet operates fine but the motor does not go. I have changed the brushes and there is electrical contact between them. It seems that the motor is not getting power.
  • 2 more comments
  • Wbix Apr 08, 2015
    I solved this problem by recognising that the motor was OK and the connectors were OK so it must be the controller board.
  • Wbix Apr 08, 2015
    The controller board sit's behind the front panel controls and was a pig to remove. I broke plenty of those plastic clip things that hold it in.
  • Wbix Apr 08, 2015
    On examining the circuit board I noticed a dry solder joint on what looks like an important power transistor. After resoldering the joint and re-assembling the machine it's now washing clothes :-)
  • Wbix Apr 08, 2015
    I suspect that motor brushes are the usual thing to fix first since they are easy. However I suspect that the arcing brushes, which were worn all the way down, had caused heat build up in the transistor solder joint. Fingers crossed it's all super now :-)
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 13, 2015
Testimonial: "This washing machine has none of those parts. It's belt drive and has no transmission or clutch or electromagnetic whatsit. You might also note that I said it followed it's program, which it would not do if the door switch said the door was open. Read my comments how I fixed it. However it's still not doing it's 1200rpm spin."
  • 1 more comment
  • Jorge Rendon
    Jorge Rendon Apr 15, 2015
    Oh Im sorry I assumed it was direct drive and yes u do not have a tranny or clutch but u may have what is called a SPLUTCH AND A MODE SHIFTER. These engage and disengage the machine in wash and spin cycle. if the mode shifter does not disengage it will not allow a spin? likewise the SPLUTCH WORKS IN SAME MANNER IT IS LOCATED UNDER THE DRIVE PULLEY
  • Jorge Rendon
    THIS IS APPLICABLE TO MOST DRIVE BELT MACHINES SORRY iM NOT SURE ABOUT A bosh but assume its the same
  • Wbix Apr 15, 2015
    Jhonny I am pretty sure there is no splutch. The motor is mounted on the bottom side of the tub and has a simple grooved pully on the end of the motor. The motor connector has several pins, maybe 8. I suspect it achieves different speeds by driving the coils differently rather than needing a clutch or gearbox. I suspect the problem is in the control panel PCB. I suspect it was caused by back EMF sparks from the worn out brushes. The machine is like a man with a heart condition. It just about functions but not very well.
Bosch classixx washing machine over fills, stops for 5 mins,drains water and stuck on rinse without doing the wash cycle. it spins when spin cycle is manually selected.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 25, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Cabrio start button flashes but doesn't start.
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
BOSCH WASING MACHINE WONT SPIN OR FINISH CYCLE AND MAKES CLOTHES DIRTY
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jun 27, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Repair Manual for WFB4000 washing machine
Jun 11, 2012 | Bosch Washing Machines
I have an older Ge model WWA5600G and the activator does not move back and forth to clean the clothes. The spin cycle is fine
Apr 30, 2012 | GE Washing Machines
Stopped spinning
Thank you for using fixya.
Sep 17, 2011 | Bosch Washing Machines
Hi. I have a Bosch WET2820GB/13 washing machine/dryer Yesterday, it stopped part way through a cycle and I have tested it several times since in different cycles and the same thing happens. The water...
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 06, 2011 | Bosch Washing Machines
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Dec 21, 2010 | Washing Machines
Bosch classixx6 1200 express - brand new
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Mar 14, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
