Re: Co ordinate black wire and white wire to power input...
Please explain the problem better, I have wire harness around the shop. shoot me a email [email protected] with model number and I can tell you if I have the parts
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
The factory plug should be whitish-clear and have the following wires
Yellow=power input
red=switched power input (accessory)
black=ground
orange or orange/white=illumination
blu=power antenna trigger
blu/wht=amp turn on
the speakers will be pairs of colors, the one with the black stripe is negative:
whites=left front
greys=right front
violets=right rear
greens=left rears
black = ground dark green = lights on input grey = panel lights pink = on input yellow = power input orange = battery power input
nca = shield ground tan = left fr spkr + orange/black = left & right spkr -neg lite green = right fr spkr +
nca = shield ground dark blue = right rear spkr + dark green/yellow = right & left spkr - neg brown = left rear spkr +
purple/white = display dim output pink = vehicle speed input ----------------------------------------------------------------------- **** 91 park ave without delco bose =
grey = left front - neg tan = left front + pos dark green = right front - neg light green = right front + pos
black = ground dark green = display dim signal grey = panel lights pink = power antanna yellow = ign input orange = battery power light blue = right rear - neg dark blue = right rear + pos yellow = left rear - neg brown = left rear + pos .
red - power Black - Ground Blue/Black - rear Left Speaker Positive Blue - Rear Left Speaker Neg White/ Black - Front Left Speaker Positive White - Front Left Speaker Neg Brown/Black - Rear Right Speaker Positive Brown - Rear Right Speaker Neg Yellow/Black - Front Right Speaker Positive Yellow - Front Right Speaker neg Green - Left Input Positive Green/White Left input Neg Gray Right Input Positive Gray/White - Right input Neg
