Question about Coffee Makers & Espresso Machines
How can I remove the replacement handle that was sent after the recall? It's so ugly!
How do I remove & replace carry handle?
Refer this issue directly to Electrolux for guidance in replacing the handele.
Jan 25, 2014 | Electrolux EL6988E Oxygen Canister HEPA...
Tip
How to Recall a message in Outlook 2007
Did you ever send a message to the unintended recipients? And wondered how you could take the message back. This tip will help "Recall" a message. If you are using Outlook (specifically 2007) this will guide you how to take a message back from unintended recipients.
Here are the good things about this feature:
* You can recall the message that was sent to unintended recipients.
* You can recall the message that you were not yet suppose to send. Probably you are not yet done writing or you accidentally hit the send button.
* You also have an option to recall the message that was sent and replace it with a different message.
This is a down side with this feature. If your message was already opened or read by the recipient, you will not be able to recall the message.
Now here is how you do the "Recall" in Outlook 2007:
1. Go to your "Sent Items" and open the message that you can to recall.
2. On the menu bar click "Other Actions" and click on "Recall this Message".
3. A small window will pop-up and you will have different options on how you will recall the messages. Here are the options:
  • Delete unread copies of this message.
  • Delete unread copies and replaced with a new message.
  • Tell me if recall succeeds or fails for each recipient.
Delete unread copies of this message - Will only recall the message and delete it.
Delete unread copies and replaced with a new message - This will recall the message and will give you an option to put in new reply. This is like make a new reply that will replace the original message that is being recalled.
Tell me if recall succeeds or fails for each recipient - I recommend that you leave this setting checked to make sure that you will receive a confirmation if the recall succeeded/failed for each recipients.
I would like to emphasize that the recall will only succeed if the message was not yet read or opened by the recipient/s. I hope this will help you guys.
on Feb 13, 2010 | Microsoft Office Outlook 2007: Windows
There's a hole or a crack in the gas line between the fuel injectors on top of the engine. It is causing a gas smell in the car. Is this a recall item?
recalls are listed here: http://www.edmunds.com/car-maintenance/recalls.html?year=2002&make=&model=&styleId=100003002&engCode=6INAG4.0&transCode=AUTOMATIC&mileage=100000&zip=45390&type=recall
I don't see one for the rail. Recommend you relieve the pressure, mix up some JB Weld epoxy, and put a big glob on there. Make sure it is set enough not to slide off, then let it set overnight. It might take a few overnight applications to seal it. This is ugly but a lot easier than replacing the rail. It might at least get you by until it's convenient to take the rail off.
Dec 21, 2010 | 2002 Jeep Grand Cherokee
I want to recall a message after it is sent in MS Outlook 2007
Please find your answer below:
If you have Microsoft Exchange account as you said, you can manage to do that. Because, this feature requires you to use a Microsoft Exchange Server 2000, Exchange Server 2003, or Exchange Server 2007 account.
The recipient of the e-mail message that you want to recall must also be using an Exchange account. You can’t recall a message sent, for example, to someone's personal Internet service provider (ISP)
(ISP: A business that provides access to the Internet for such things as electronic mail, chat rooms, or use of the World Wide Web. Some ISPs are multinational, offering access in many locations, while others are limited to a specific region.) POP3 (POP3: A common protocol that is used to retrieve e-mail messages from an Internet e-mail server.) e-mail account.
For all recipients who haven't opened the message yet, you can perform an e-mail sleight of hand and replace the original message with another one that contains the attachment.
To Recall a message Do the following: If you want to recall the message but not replace the message :
  1. In Mail, in the Navigation Pane (Navigation Pane: The column on the left side of the Outlook window that includes panes such as Shortcuts or Mail and the shortcuts or folders within each pane. Click a folder to show the items in the folder.), click Sent Items.
  2. Open the message that you want to recall.
  3. On the Message tab, in the Actions group, click Other Actions, and then click Recall This Message.
4. Click Delete unread copies of this message.
NOTE: If you are sending the message to a large number of people, you may want to clear the Tell me if recall succeeds or fails for each recipient check box.
1. Select whether you want to only delete the message or delete and replace the message.
2. Select the check box to receive a confirmation that the recall was successful.
NOTE: Yo can also recall and replace the message.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Microsoft Office Outlook 2007: Windows
How do I recall a message?
If you are referring to recalling an e-mail message, it will depend on your ISP (most do not support this function). If your computer is going through an Exchange Server to handle your e-mail, then you can recall a message that is on the internal network only. You would go to your sent items in Outlook, open the e-mail you want to recall, click on actions and select recall message and follow the prompts. Otherwise, an e-mail going outside of the organization most likely cannot be recalled.
Jan 25, 2010 | Computers & Internet
Interior light stay on with doors closed and switch off, had to remove fuse.
Could be a door switch gone bad, but my gut feeling is that the module that controls the interior lights (which may be part of a body control computer on that car -- I'm not sure) went south. The lights are almost never controlled directly by the switches any more -- that's why they can stay on for a minute after you get in and shut the door, turn on when you pull the door handle, fade off instead of turning of abruptly, and all of the other neat tricks today's cars do. Some have a separate module to do these tricks and others incorporate it into a computer that runs all kinds of things (interior lights, wipers, 4WD control, etc.) I'd certainly check the door switches first -- they're cheaper. However, as I said, my gut is saying that it's that module.
Nov 28, 2009 | 2004 Dodge Durango
We are only getting hot water out of one bathroom shoulder handle and cold water only out of the same fixture in another bathroom. I recall taking apart one of these shower handles in the past and...
Okay, that's what I thought. Rmove the handle (may be a set screw to loosen), remove the nut holding in the stem (or maybe the stem screws out), remove the cartridge. If it's not clogged it probably needs replacing.
Oh, yes, first turn off water to fixture...
May 04, 2009 | Home
1995 jeep grand cherokee loredo recalls one from 95 other 2002
I am not sure about the clarification request. But if I enter this as a solution then you can give credit. I am glad I could help.
Have a nice day!
Mar 28, 2009 | 1995 Jeep Grand Cherokee
Stoneware slow cooker
I have looked everywhere and can't find a specific replacement for your crock.
The only recommendation I have at this point is to contact Rival. They have a customer service email that you can send them a message through their Help menu.
http://www.rivalproducts.com/help.aspx?helpNav=3
I sent them a message asking about a replacement for your crock specifically but they wanted more information than I had to give them (something about a number on the bottom of the crock pot).
Give that a try and perhaps they can get you a replacement?
Good luck...
Feb 11, 2008 | Crock Pots & Slow Cookers
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
