Question about Health & Beauty
Hornady G-S 1000 electronic scale. Display error
Need a bullet drop chart for a 1917 eddystone 30 06 with a 26 in barrel using hornady 150gr round.
Results are really only needed for caliber, load (in grains) and round in weight and style.
    [PDF]Standard Ballistics Chart - Hornady
    www.hornady.com/assets/files/ballistics/2015-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET. ITEM #. MUZ 100 yd 200 ..... Bullet. LRN . . . . . Lead Round Nose ..... 0. -6.4 -18.8 -38.3. AW 30-06 Springfield. 150 gr. InterLock® SP. 8108. 2910. 2637. 2381. 2139.
    [PDF]HMC 07704 Ballistics Charts as PDFs - Hornady
    www.hornady.com/images/ballistics/ballistics_charts.pdf Velocity (fps) / Energy (ft/lb). Trajectory Tables. CARTRIDGE. BULLET. ITEM # ..... LM 30-06 Sprg. 150 gr. SST LM InterLock. 8519. 3100/3200. 2867/2736. 2645/ ...
    [PDF]Hornady ballistics charts
    www.hornady.com/assets/files/ballistics/ballistics_charts.pdf Trajectory Tables. CARTRIDGE. BULLET. ITEM # HITS #. MUZZLE. 100 yds. 200 yds ..... C 30-06 Sprg. 150 gr. SST InterLock. 8109. 911. 2910/2820. 2686/2403.
    [PDF]Trajectory Tables - Hornady
    www.hornady.com/assets/files/ballistics/2013-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET ...... 30-06 Sprg. 150 gr. InterLock SP. 8110. 2910. 2637. 2381. 2139. 1911. 1700.
    30-06 Ballistics Chart & Coefficient GunData.org
    gundata.org/blog/post/30-06-ballistics-chart/ Jul 11, 2012 - ... 1000 yard 30-06 ballistic charting of a Remington 30-06 Springfield 165 Grain AccuTip Boat Tail with a BC (Ballistic Coeficient) of .447 that was created using our free ballistic trajectory calculator. ... 150, -1.1424, 2499, 2288, 0.17 ... 600 Round Glock Magazine · 10mm vs 40 Summary and Ballistics · How ...
    30-06 Springfield / Hunting & Ballistics:
    www.gunnersden.com/index.htm.30-06springfield-ballistics-hunting.html External ballistics pertains to bullet velocity, energy and trajectory down-range. ... Below are several hunting ballistics sight-in charts for 30-06 Springfield ammunition that ... Ammunition manufacturer: Hornady. ... Bullet weight: 150 Grains.
    30-06 Springfield:
    www.gunnersden.com/index.htm.30-06springfield.html 30-06 Springfield Cartridge, Rifles, Reloading And Ballistics Information. ... Ammunition: Hornady 150 grain SST bullet. Bullet diameter: .308 inch. Bullet
Jan 19, 2016 | Optics
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of Thinner® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you live® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
Dec 11, 2008 | Conair Large Digital Display Memory...
Health & Beauty Logo
48 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
