Question about Mitel Superset 4025 Corded Phone (mitsup4025)
How do I cancel I am here from the station I set it up (mitel phone) or from the station I had forwarded (analog)?
I know how to cancel from Mitel to Mitel but I am running into an issue whereby I had the analog extension forwarded to a Mitel phone utilizing the "I'm here" call forwarding function. Now I can't cancel that feature. Please help!
    Problem Solver:
  • 14 Answers
If you forwarded the analog to the digital you probably used a feature access code. So this code will either turn it off if entered into the forwarded phone. Or there is a call forward cancel fac that would turn it off. There may be a clear all features code that programmed that would cancel the forwarding as well. All of these options would need to be dialed from the forwarded (analog) phone.
Posted on Apr 09, 2015
  • Anonymous Apr 10, 2015
    I forwarded the extension from the mitel phone so I didn't use a feature access code. Just used the "I'm here" option from the Superkey call forwarding options. We had to reset the mitel phone to clear the forwarded phone. Thanks!!!
5 Suggested Answers
  • 112 Answers
SOURCE: Mitel superset 4025 - setting up a number to forward phone to
It is probably a system speed dial number. What mitel system do you have?
Posted on Jan 11, 2009
ynotphone
  • 192 Answers
SOURCE: extension check
What you typically do is, press the blue Superkey and press the intercom button.
This will display what is on every key, as well as the extension number of the set.
Posted on Mar 20, 2009
  • 37 Answers
SOURCE: Call forward is "not allowed"
This is a "Class of Service " option, in the system programing under class of service look for the option "call forward to external Destination" this needs to be set to allow.
Posted on Dec 24, 2009
  • 378 Answers
SOURCE: How do i set call forwarding to a cell phone #?
Press Superkey
Press More until the Forwarding softkey appears.
Press the forwarding softkey
press either busy, no answer or always softkey.
if you pressed busy or no answer, press Internal, External, or Both softkey.
Dial the destination number.
Save on or Save off.
press superkey.
Posted on May 01, 2011
Will the uperset 4015 work with a magick jack?
No. The Mitel Superset 4015 is a proprietary digital phone that will only work on Mitel telephone systems. It will not work on some of the older analog Mitel systems.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
Press Superkey
press superkey.
Jul 23, 2010 | Mitel Superset 4150 Phone
Caller id displaying DID's
It sounds coincidental. You should contact your vendor as I think there is something in the programming that's changed. Either in the set's class of service or in the trunks class of service.
Jun 07, 2010 | Mitel Superset 4025 Corded Phone...
How do i set up call forwarding to my cell phone - with my Mitel 4025? Thank you, Sean
just go to settings option then call settings and select call forwarding or divert call and insert the number you would like to forward the incoming calls to
Apr 16, 2010 | Mitel Superset 4025 Corded Phone
Won't go to Voicemail
You will need your system administrator to change the call reroute assignment of your phone, or you have call forwarding active to a location the system can not route a call to. Either scenario your phone administrator can resolve quite easily.
Sep 02, 2009 | Mitel 5220 IP Phone
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Want to divert calls from one Mitel Superset 4025 to another.
Under the Blue Superkey, there is an option for Call Forwarding.
Go to the call forwarding and put in the extension that you want to forward to, and then enable it.
To disable the call forwarding, you have to go back into the Blue Superkey and disable the call forwarding from there.
It's either that, or your system programmer may have given you a call forwarding button on the set to enable and disable easier.
Nov 24, 2008 | Mitel Superset 4025 Corded Phone...
Wanted to use two mitel 5303 for one conference call
Yes you would have to have them on seperate analog phone lines and 1 would have to dial the other. To add a 3rd party you have hit the flash button dial the other party, connect, and hit flash again.
Mar 19, 2008 | Mitel 5303 Conference (50001905)
Mitel 420 superset
Message system does not work, system wide or just at your ext.? If it doesn't work system wide you have big problems. If it is only at your ext. your call forwarding maybe turned off. press superkey then press next til you see call forward and set it up. You Need to know pilot number to Voicemail.
Sep 25, 2007 | Mitel Superset 420 Corded Phone
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
141 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
