AUTO FAN NOT WORKING BUT FAN ON WORKS - Heating & Cooling
    New Friend:
  • 3 Answers
Sounds like the thermostat is either defective or has a bad connection. If you are familiar with using a multimeter (volt-ohm-current meter), it would be the device to use to trouble-shoot this problem. MAKE SURE THE HEATER IS UNPLUGGED!!!
With the meter set on Ohms, and the heater set on auto, set the heater to its lowest temperature setting. You want to see no resistance (close to zeor Ohms) when check across the thermostat (the temperature knob mounts on it). If you see high or infinite resistance, the thermostat's open and therefore defective. If the thermostat checks out OK, continue checking with the meter. You should have about zero Ohms between the hot pin on the power plug (the narrower one in N. America) and the heater motor lead. If it's open (high or infinite resistance), keep the one meter lead on the power plug and trace back, checking each connection until you find the defective one. Don't rule out a broken wire, maybe inside the insulation (but unlikely).
Posted on Apr 08, 2015
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
My termost set to a/c, the fan auto, blow very well, but when I switch to heat and the fan auto, doesn't work, but if I put fan on work why?
the thermostat says to call for heat buildup in the work if its not cold enough the thermostat won't call for heat and I won't go on but when it gets cold and the thermostat set to the temperature you want or hire someone that doesn't cycle
Oct 12, 2014 | Heating & Cooling
Auto shutdown during work
it could be that the fan of your processor stops working or not working at its full efficiency, you should check underneath your laptop unit if the processor fan that blows away the heat generated by processor and chipset during heavy load of work.
Oct 21, 2013 | Lenovo Computers & Internet
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 25, 2017 | Honeywell Electronic Programmable...
I have an evaportating cooler omega it only works on fan.
I would have the unit looked at. The auto section on the motor is turned on by the cooler automatically so there seems to be a problem there at that switch.
Good Luck on your repairs hope this helped some
Dave
Nov 09, 2009 | Heating & Cooling
I have a Honda 1991 2.7i Legend Auto. auto
Dual fans if yes. one fan is bad
Jul 14, 2009 | 2000 Honda S2000
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
