Question about Bosch Dishwashers
Water coming back into bosch dishwasher
After cycle finishes fine mre water than usual in bottom of tub. cleaned filters and impeller and no obstructions. emptied water out of bottom, turned off water source and couple of hours later more water in the bottom again. any ideas???
  • 152 Answers
Check the drain hose that goes into sink cabinet. It should loop up as high as it can go so that water from the sink or disposal doesn't siphon back into dw.
Posted on Apr 09, 2015
  • Anonymous Apr 09, 2015
    have already done that and have alos checked for blockages in sink drains and nothing.
Dishwasher won't drain completely
perhaps it need that air gap device added .we call it a siphon break here .
Sep 06, 2015 | Bosch Dishwashers
Bosch goes straight to clean cycle
I had the same issue, for me this is what solved it.
Clean out the drain filter, remove any water that's still in there using a ladle/sponge/cloths, remove the impeller cover and make sure the impeller is spinning with no resistance. may be some food debris that got stuck or the filter may just be very clogged. Give it a try, it's a simple procedure:
This is from Bosch UK's youtube page:
http://www.youtube.com/watch?v=hfw3vliCf4c
Worth a try!
Sep 11, 2014 | Bosch Dishwashers
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Water is left when cycle is finished
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 26, 2011 | Bosch Dishwashers
Our bosch dishwasher runs but no water is spraying on the inside. Is there a water filter clean out or is there a water pump that might be broken? I checked the line coming in and it isn't plugged. I...
Hi, welcome to Fixya. By the description you've provided, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. Essentially what it say's is this...Remove the pump filter ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight so it's a well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visiting "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not let me know. Thanks again and good luck. Macmarkus :)
Jun 13, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Kenmore dishwasher is not washing properly and leaving dirty water in the bottom when it is finished, Can i fix it?
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jun 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
My bosch shu5315 cycles fine but when finished water is not draining completely. checked screen-cleaned-and problem still exists. Is it the heater? If so how hard to replace?.Note: remaining water fills...
check your airgap by the faucet of your sink. usually a metal cylinder is the cap. then you might have tabs to press in, or the top of the airgap can unscrew. usually i find stuff in there. mostly fishbones.. otherwise make sure the holes towards the bottem left of your dishwasher tub under your filters arnt clogged up. sometimes calcium gets in there a clogs those holes to the drain pump.
if no airgap then check that hole to the disposer. reach your finger in there towards where the dishwasher drain line is coming in and make sure that isnt clogged up.
Feb 24, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
Water will not drain.
This problem is often due to a blockage in the impeller blades which are located under the filter at the bottom of the dishwasher. Remove the filter and you should be able to get to the impeller by undoing a couple of torx screws. If the impeller has been blocked (this could be by something as small as a grain of uncooked rice), remove the obstruction so the impeller turns freely.
Nov 04, 2006 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Dishwashers Logo
120 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
