Question about Brother Sx-4000 Elec Lcd Disp Typwriter W/ Dictiona
The striker doesn't move. how do I tell what the problem is.
  • Anonymous Apr 10, 2015
    the striker doesnt operate when a key is pressed. is the striker broken or is there another piece that isnt working. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Need proffesional repair, the mechanisms in the machine are broken.
Usually not worth the repair
Posted on Jun 24, 2016
Theh trunk on my 2013 ford focus randomly pops open while driving on highways , what could the cause be and how can i fit it ?
The striker assembly may be out of adjustment. This is the metal piece that the trunk lock assembly grasps when the lid is closed. These strikers usually have bolts that can be loosened allowing the striker to move up and down to obtain proper adjustment so the trunk will open/close properly
Dec 26, 2015 | 2013 Ford Focus
My trunk wont shut on my 1991 buick park ave. Is the bottom part of the latch supossed to be at an angle?
CHECK FOR LOOSE BOLTS AT THE LATCH STRIKER IF BOLTS LOOSE MOVE STRIKER TO CORRECT POSITION SLOWLY CLOSE TRUNK LID UNTIL THE TRUNK LID LATCH AND LATCH STRIKER COME IN CONTACT TO CLOSE TRUNK.ONCE BOTH ADJUSTMENTS CORRECT. TIGHTEN THE LATCH STRIKER BOLTS TRUNK SHOULD NOW CLOSE.
Jul 25, 2011 | 1991 Buick Park Avenue
Trunk will not latch onto the striker bar seem to be to short, can it be adjusted?
either the striker, or the latch will be adjustable. Look for the bolts that you loosen to move it.
Dec 25, 2010 | Honda Civic Cars & Trucks
The tailgate latch, doesn,t latch
you have to make sure the strikers are lined up to the latch. The latches get dirt in them and dont move easily. You may have to remove the latches and clean them and grease them up make sure the action is working. There is a spring on the latch if it is broken you will have to replace the latch. Make sure as you before you shut the tailgate the the latches on the tailgate are open and not latched closed. You can put a screw driver in the latch and pull the handle and that should release the latch in the position ready to accept the striker when you close it Next make sure the plastic clip retainers are not broken on the handle
Dec 11, 2010 | GMC Sierra 1500 Cars & Trucks
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
I **** the marker. screw in hpa. so far so good. no leaks. fire it a few time and there is a leak coming from inside. i can hear air from barrel and the oval cocking handle hole. i have taken apart the...
Replace all of the o-rings within the gun make sure that the striker pin is free to move. The striker pin is the one that the big striker hits, it is on the inside of the pressure tube.
Apr 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Brother Sx-4000 Elec Lcd Disp Typwriter W/ Dictiona Logo
228 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
