Question about Electrical Supplies
Turn on steam in shower, but no steam comes out
  • 152 Answers
So many things could be wrong. 1 check circuit breaker. 2. Check there is water going to steam unit. Power to control in shower? Steam unit could be burned out. Or control is not working or thermostat not working.
Posted on Apr 09, 2015
My Breville BES820XL isn't steaming the milk. Instead it drips a little and then the steam comes out the shower head. Any idea what is causing this and how to fix it?
Maybe the end of the steam wand is clogged. Use the tool that comes with the maker to clean it. Do this with the coffee maker turned off.
May 06, 2015 | Breville BES820XL Espresso Machine
Water is pouring out of pipes where steam should be coming from- ? - Please advise
Paige - your question appears in the "Shower hardware" section.
Steam - from a shower head?
Water should be coming from a shower head and steam is in your radiators - not the other way around. Please provide more info on the products or system you're having this trouble
Dec 10, 2014 | Home
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable...
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
May 14, 2014 | Home
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
How do you you replace the steam ring in a Breville 800ESX? I bought one and would like to have some detail before I take it apart. I see the 4 screws underneath but it look like if I loosen them it will...
This is the easiest repair you will make. Turn machine upside down. Remove screw located in center of shower head (round screen-like thing in brew head). Rubber steam ring can now be lifted out, or it will come out with the shower head. Position new one onto shower head and screw back in. Done.
Jul 02, 2011 | Breville Die Cast 800ESXL Espresso Machine
My steam shower is dripping water when it is turned off... all water is turned off.. please contact me since my water is dripping and is costing me money! the drip is where the steam comes out.. my number...
You have to turn main water off to house, then in side shower head is a gasket / otherwise known as a 0-ring, that needs replacing. Yes, a 50 cent part is causing this. If you don't know how to replace shower head 0-ring, just take shower head to any home depot,they will put it inn for you. Just make sure you turn main water line to house off, otherwise real leak. Let me know if helps. Thanks mike
Jun 22, 2011 | Thermasol Electrical Supplies
Steam shower wont turn on getting a flashing temp on controller in shower
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Nov 14, 2010 | Mr Steam Ms Super 1e Steam Shower...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Electrical Supplies Logo
180 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
