Question about Konica Minolta magicolor 4750DN Duplex Color Laser Printer
How to enter the service mode konica minolta 4750dn
SOURCE: service manual?
that is the user manual and not the service manual!
Posted on Jan 20, 2008
goalie39
  • 469 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
  • 12 Answers
SOURCE: How do I get into service mode on a Konica Minolta
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
Posted on May 15, 2009
  • 32 Answers
SOURCE: Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Posted on Jul 03, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
How can i enter the service mode for konica minolta bizhurb 250/350 black an white copier and how to adjust ATDC and to run f8?
To enter service: utility/counter, counter details, stop, 0, stop, 0, 1, then 00000000. F8 is found under functions menu. ATDC is run by F8.
Aug 11, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Service mode konica minolta bizhub C224e
Utility-stop-00-stop 01 press enter press 00000000 enter end
May 28, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c451 service mode password reset
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Mar 14, 2014 | Konica Minolta Office Equipment & Supplies
Envelopes wrinkles after running through printer
Minolta does recommend stuffing the lip inside the envelope before running. But I think it only helps with jamming. Plus high humidity can cause wrinkling.
Mar 14, 2013 | Konica Minolta Office Equipment & Supplies
Where is the waste toner bottle on magicolor 4750 printer
the waste toner bottle should be below the toners themselves as seen here: 2_20_2013_9_33_39_pm.jpg
Feb 18, 2013 | Konica Minolta magicolor 4750EN Color...
Konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
Jan 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Konica Minolta magicolor 4750DN Duplex Color Laser Printer Logo
421 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
