Question about LG Televison & Video
In lg golden eye there is no av signal in av1 and Av2 why?
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
SOURCE: NO AV1 AND 2 VIDEO SIGNAL
tv start working on its own.
Posted on Jun 27, 2008
  • 52 Answers
SOURCE: LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Posted on Aug 12, 2008
  • 29 Answers
SOURCE: Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
Posted on Jan 22, 2009
  • 15 Answers
SOURCE: How do I hook up my digtl cable and dvd to my Vp422 vizio tv
Surround Sound to 8 or 9 8 is best
DVD to HDMI 1
Direct TV to 10
If you have these connections on your peripherals, this is recommended..
Posted on Sep 11, 2009
How do I record from DVD to HDD
DVD player AV out to HDD AV in RCA cable red white yellow
HDD input source has to be AV in you may have to set up a timed program chanel to av in av1 or av2
you may not be able to do this due to copyright embedded signals being detected by the HDD
Oct 17, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
Sinotec TV, I'm trying to connect dvd or Ps it says no signal
Check your AV cables. when the AV cables are connected to the TV, select AV mode on your TV. Remember you might have more than one AV mode ie AV1, AV2, AV3.........
May 21, 2016 | Televison & Video
I was av1, av2 before but now i can't access my lg 42'' flat screen A2
Hi happy,
This happens quite often due to current leakage from signal box.. Please continue with AV1. But Have your cable box or whatever signal box you are using for any current leakage so that AV1 remains safe. If you lose AV1 too, you may have to replace the main board.
May 07, 2015 | LG Televison & Video
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Problem with AV Input and TV signal distorted but i know signals are fine from source
change devices to other ports, if you are sure some ports are not working properly then you will need to replace the mainboard.
May 16, 2009 | LG L172WT 17 in. HD-Ready LCD Television
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
