Question about Dell LATITUDE Computers & Internet
Where is the bios located on the board? - LATITUDE Dell Computers & Internet
  • Steve Harris
    Steve Harris Apr 08, 2015
    Hi collyod , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Would need to know which motherboard you have first
    Sergeant:
  • Dell Expert
  • 352 Answers
Hi Collyod,
BIOS is a type of firmware which used during the boot process on Dell computers. BIOS can be accessed by tapping the F2 key at the startup.
Also let me know if there are any issues with the computer.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Posted on Apr 10, 2015
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
Where will the restart and power cable will be connected in motherboard i5 Intel
Download the Technical Manaul of Motherboard from following link.
https://downloadmirror.intel.com/18505/eng/DH55TC_ProductGuide01_English.pdf
On page 12 of the manual you will find the diagram of your board. The power connector is located at position "N". Hard reset feature is not provided in this board as it was available in old mother boards. However System Recovery can be performed using BIOS Jumper located at position "P" on the motherboard. Remember that BIOS Configuration Jumper is used to for System Recovery not for Reset.
Oct 10, 2015 | Intel H55TC Motherboard Core i5 650...
Where is the bios chip on dell latitude e6400 mother board
For reseting BIOS, you should first try to remove CMOS battery. Put it back and BIOS reset is done. For location of CMOS battery, check laptop manual.
But first, you could try to perform factory reset on BIOS. You can access BIOS by pressing F2 during startup.
May 13, 2014 | Dell Latitude D600 Notebook
Dell 1100 bios password
just take out the battery wait 1 min then put in battery
Jan 10, 2014 | Computers & Internet
IBM x3550 Server
You will need to remove the cover and locate the jumper that controls your BIOS setting. (Sometimes located near the back of the server board by the power supply. Check your owners manual for exact location.)
Move the jumper the BIOS reset, power on your server and follow the onscreen instructions. When complete, move the BIOS jumper back to regular position (1 and 2) and reboot.
Good Luck
C2Solutions
Feb 15, 2012 | IBM x3550 Server
Hi, I started having problem with my motherboard. First thing happened is: I turn it on the computer->windows update->couldn't go to my start up desk system were frozen. ->reloaded...
Try resetting bios. This is done by a small jumper on most modern boards. location on your board. Try resetting bios. This is done by a small jumper on most modern boards. See image for the location on your model. Simply take the jumper (it is the plastic piece on two metal prongs. Move it so that it is on the middle and opposite prongs. to be sure of the reset start and after a 5 count turn off your pc. Move the jumper to its original position. This should allow you access to bios. nathan_f_0.jpg
May 14, 2011 | ECS 945P-A (V3.0) Motherboard
My notebook MSI U100 PLUS has a password on bios i can't enter bios to change frist boot to CD THANKS
did u can reser pasword if remove the battery no conect to energi and remove the bios batterry. bios battery are located on mother board.
Nov 24, 2010 | Computers & Internet
Will not boot comes up wth a 9F Error on the mother board.
The F( error message at boot usually indicates that BIOS has detected an error that will not allow it to continue, If you can enter BIOS, try loading Bios Defaults, If you cannot enter BIOS, find the jumper or switch on your board which says CL CMOS, Move the jumpers to the CLR CMOS position for about 3 seconds and then replace it in its original position.
If this does not take care of your problem, I would suggest you one at a time remove each card/ periphial untill you can locate the offending item....I know.....Pain in the rear, but unless you have the diagnostic equipment to locate the problem for you, A neccisary step.
Hope this helps.
Ed
Jun 08, 2010 | Abit AG8 Motherboard
How do I Find, Identify & Replace Bios Battery on my C502US
hi,
The board on that laptop uses a traditional CR2032 battery. This battery you can find at almost any jewlers or electronics shop.
(ref)
You can see it in images such as this one or this one.
Now you knwo the battery type, and where in the board is located :)
As for how to access it I think this instructions (see step #13) are very similar for the C500 or given the physical similarities use the C300 instructions.
Hope this works,
Ed
Nov 24, 2009 | HP Compaq Presario C502US Notebook
I need a driver for my old elpina BA E-VO 9817
Ok on the board you should have a bio chip. If you can tell me if it is AMI or something else, and provide the bios string, I might be able to locate the manufacturer of the board and see if I can locate the drivers that you require.
Apr 29, 2009 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
