Question about Thermador Refrigerators
Thermidor refrageder it noisy and blinking
Noisy and the numbers are blinking
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Noisy Evaporator Fan on a Kenmore model 596.76579600 refrigerator
The replacement evaporator fan for your model is a part number 12002744
Posted on Mar 15, 2009
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Kenmore Electric Dryer HE2 model 110.8756 really noisy with screeches and rattles when running. Dries fine but really noisy. Used to be quite as a mouse.
there's a belt kit you can buy that comes with a new belt,rollers and the belt pulley.this should take care of it,you have to send the whole model number so i can look up your machine.
Oct 07, 2013 | Kenmore Dryers
Ford Mondeo 2010 lifters noisy
Hi, the lifters can be noisy of luck of oil. Check what oil should be used on your car specification. If they still noisy that mean you need to replace them.
Jul 23, 2013 | 2010 Ford Mondeo 1.6
Mar 15, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Mar 07, 2009 | GE Dryers
Noisy noisy noisy!
Without being there, it is hard to say. You need to consider tire condition - large mud tires are noisy; tires over inflated will be noisy; a bad driveline u-joint will make noise; drive line bearings, wheel bearings all could be a factor. have a mechanic friend ride with you and help pinpoint the cause.
Feb 15, 2009 | 2002 Mazda Tribute
Agitator is noisy
I think you may have a bad transmission. this uses a direct drive transmission
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running.
Your complaint is;"Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running".
You have not provided a brand name or model number. I I can only offer information based on genric or common solutions. Below is a link that should prove helpful if you need additional information.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 15, 2008 | LG Dryers
Open Questions:
Refrigerators Logo
49 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
