Question about Exercise & Fitness
I have a c950pro. Console says it's at max incline. But it's level. All it will do is beep when you push any button
    New Friend:
  • 41 Answers
Calibrate the incline by holding the stop and speed + button at the same time as putting the safety key on. Press stop button once and then press the +incline button and treadmill should calibrate the incline. If that does not you need a new incline motor. shoot me a email at Elitefitnessrepair@gmail.com and I might have a incline motor for you
Posted on Apr 09, 2015
SOURCE: My console does not allow me to change the
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Posted on Oct 14, 2009
Testimonial: "He asked the right question."
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
2manyhobbies
  • 129 Answers
SOURCE: Is there an online repair manual for the Golds Gym
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Posted on Mar 01, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
Pftl788071 incline
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
Apr 14, 2014 | Proform Exercise & Fitness
Max pro vibelife 975 treadmill
follow this steps for program.God bless you
Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Oct 01, 2013 | Exercise & Fitness
Nordic Track T5.3 is does not run only inclines to the highest level and back down, what could be the problem?
please RUN the software calibration and fix it
.God bless you
The Steps for Newer Style Console Calibration
11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 13, 2013 | Nordic Track Exercise & Fitness
PaceMaster Bronze Basic err 119
Run the software calibration for easy diagnose, and troubleshooting see the steps. and Block diagram
God bless you
Jan 14, 2013 | PaceMaster Bronze Basic Treadmill
How do I calibrate speed on a Proform 725TL treadmill
follow the steps that i am giving now.
God bless you
Jan 10, 2013 | Proform 725tl Treadmill Drive Motor
Is there an online repair manual for the Golds Gym Advantage Treadmill? I'm trying to solve an incline problem. The incline does not go up when I push the incline button. I just get a series of beeps...
Mar 01, 2011 | Exercise & Fitness
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
Exercise & Fitness Logo
79 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
