Question about Dryers
The front drum felt went bad and from what I have found is that you have to purchase the entire drum assembly to repair this, anyone know of a fix or felt that can be purchased to repair this unit?
The opening on the drum is 24 1/2 OD
  • Dryers Master
  • 2,184 Answers
Try appliancepartspros.com, RepairClinic.com, or ebay.com for ur felt replacement.
Posted on Apr 08, 2015
    Top Expert:
  • Dryers Master
  • 44,428 Answers
Since you did not see the need of adding make and model in your post I can see no way we can assist you
Testimonial: "Sorry I thought I did add it, the model is a Maytag MDG6700AWW"
Felt belt found inside of drum
Hi - these are used to minimize the metal to metal contact of the drum & housing.
One will need to remove the top & front panels to gain access to remove the drum, afix felt to end in question and assemble the machine again.
Jun 14, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer suddenly began making a noise. After doing an internet search, many sources said to replace the felt and slides. Which I did and some of the slides were in fact bad. However, after replacing them and...
It could be the rear bearing ( easy to replace). I would check the idler pulley and blower wheel assembly also. Here is a link that should help http://appliancehelponline.com/dryernoisyge.html
There are also several other videos that cover the idler pulley and front bearing assembly.
Jan 29, 2011 | GE Profile Wizard DPSE592EAWW Electric...
My Kenmore Dryer Model 65732 drum won't turn. I opened up the front so that I could see the drum and I can see that the belt is okay. I can also see that the rear drum seal has deteriorated. Can anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Kenmore Dryers
Making a lot of noise!!! It dries just fine but is so noisy no matter what cycle I use. Is it a balance or a bearing problem? I'd like to repair it myself. It is 9 years old.
It depends on the type of sound. It could be felt pads going bad or the bearings. The felt pads are fairly easy to change as they are in the front under the drum and you just need to get the front off and replace them. The bearing assembly is a different story. You need to take the front and the top off (or sometimes the the top will tilt back on hinges) to access the drum you will have to remove your drum to get the bearing assembly off. The other problem could also be the pulleys underneath the dryer which can usually be accessed through a rear panel. I recommend running the dryer and listening really hard for where the sounds are coming from, you may have one of the problems you may have all of them.
May 10, 2010 | Dryers
Every now and them our dryer has peices of small blue rods by the lint trap. Not sure what these are from. Thanks
if it is light blue and made from plastic then this is the felt that locate on the bottom of your drum... i will call tec' to fix it and to check if the felts are bad.
some of my client distroy the drum when the felts went bad and they didnt stop to fix it...
Jan 20, 2010 | Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Access the drum to replace felt
To access the drum two screws need to be removed from the inside of the door. The screws are on top of the opening and hold the top of the dryer closed. Then you simply lift the top and slide it to the left to remove it, thus revealing full access to the top of the drum. Then two screws (left and right) need to be removed in order to remove the entire front of the dryer. Once the front is removed the drum can also be removed but for the purpose of replacing the felt removal of the drum is not neccessary. It should be noted that the felt sits only around the bottom of the drum and covers just over half of the circumferance of the drum. The felt should be position in around the opening of the inside part of the door. When replacing the front cover the drum will fit snuggly up against the felt. Replace screws, top and door screws and walla...fixed!
May 11, 2009 | Dryers
My clothes are getting caught in my dryer.
I am having this same problem with my GE dryer. I found a post on fixitnow.com from a guy that has repaired these for years. He says it is the rear drum bearing. Looks like a pretty easy fix, I am going to try to do it myself. If you try this, I have also read that you should spend the extra $10 to go ahead and replace the drums front felt glide kit.
http://fixitnow.com/2005/03/field-notes-frigidaire-dryer-front.htm
Good Luck!
Mar 25, 2009 | Frigidaire GLER642A Electric Dryer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes getting caught between Tub and wall inside dryer
there is uaually a rubber or composite gasket that fits inside the dryer drum with the front cover in place. the "rollers" as you call it is just pieces of felt glued to theexternal drum and front face and are the drum bearings. check appliance repair parts for the proper gasket and how to mount it to your front panel.
Dec 28, 2007 | Frigidaire FDE336RE Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
