Question about Home
The shower head drips water when the shower is turned off after ashower
  • 35 Answers
SOURCE: dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Posted on Feb 01, 2009
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
jeff_drakesr
  • 155 Answers
SOURCE: i have a drip, drip, drip from my shower head on
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Posted on Apr 07, 2010
Testimonial: "THANKS FOR YOUR HELP I WILL TRY THAT"
SOURCE: my new triton shower keeps dripping when switched off
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
My steam shower is dripping water when it is turned off... all water is turned off.. please contact me since my water is dripping and is costing me money! the drip is where the steam comes out.. my number...
You have to turn main water off to house, then in side shower head is a gasket / otherwise known as a 0-ring, that needs replacing. Yes, a 50 cent part is causing this. If you don't know how to replace shower head 0-ring, just take shower head to any home depot,they will put it inn for you. Just make sure you turn main water line to house off, otherwise real leak. Let me know if helps. Thanks mike
Jun 22, 2011 | Thermasol Electrical Supplies
Have a shower only no tub. replaced both the hot and cold stems because shower was dripping and water pressure was low. Thought if I replaced the water pressure would return. Tightened the top nut before...
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Apr 12, 2011 | Danco Faucet Stem
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
For some reason, my rain shower head drips like it is slightly turned on. I have never noticed this problem until I changed the thermostats and elements in my water heater. I believe the shower head is...
Remove the shower head and flush the plumbing by opening both valves fully. When you did the heater work, you dislodged some scale . Now it's in the shut off valve. It's no big deal as long as you hsaven't forced anything to stop it. Good Luck_Ned_
Oct 18, 2009 | Jaclo Wall Mounted Flood Shower Head -...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Sep 25, 2009 | Delta & Single Handle Shower Faucet
Dripping shower head
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Home Logo
111 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
