Question about GE 35GT740 35" TV
35 in. GE tube TV volume issue
When tv is turned on the volume is at its lowest setting. using the remote or tv buttons the volume will raise once you stop using the button volume goes back to lowest setting. This occured in a day
    Genius:
  • GE Master
  • 1,689 Answers
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Posted on Feb 10, 2009
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
GE 35GT740 35" NO SOUND
Did you try turning up the volume on the remote or front panel?
Also, try unplugging the TV from the AC outlet for about 15 seconds to make the TV do a re-set.
Beyond this, there is most likely a failure and the set will require service.
Jerry G.
Apr 10, 2008 | GE 35GT740 35" TV
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
Video mode
the answer to your ques is. go buy a universal remote control. since your tv is made by thomson electric. (ge@rca)you can prob get a rca universal remote at wallmart or walgreens. you won't need to reprogram. it everytime you change baterys. after you get set to turn on and off just hit tv/vcr button on remote or select channel 91 or 92 (on some models that is your video for rca/ge) good luck doctordave
Aug 18, 2007 | GE 35GT740 35" TV
GE 35GT690 (No remote, how do I set it to Video?)
probably you could try this push down the channel up and down button together.you menu will pop up then you can change your setting with the volume up and down button good luck.any further assistance contact me at email nicodhem@yahoo.com or on the fixya.com expert website.
Apr 24, 2007 | GE 35GT690 35" TV
Open Questions:
See all GE 35GT740 35" TV Questions
GE 35GT740 35" TV Logo
140 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
