Question about Emerson LF320EM4 32" 720p 60Hz Class LED HDTV 23871273
TV WONT POWER ON
TV WILL NOT TURN ON WITH REMOTE OR BUTTON ON TV. RERMOTE WORKS AS IT TURNS ON MY OTHER EMERSON TV AND WALL OUTLET WORKS.
  • 59 Answers
Hi does the TV have any standby light etc, if so power off at the wall and leave for 1 minute the power back on and watch the standby LED it may or may not blink try to power on if the light blinks this may be a fault code and you can search this up with the model number.
Posted on Apr 08, 2015
"Stand by" red light is on and manually pressing power, menu, etc doesn't work. Do not have a remote. How do I power on the TV?
Hello
You can turn it by pressing the button on TV back bord the a power button just click it and it will turn the TV in
Sep 03, 2017 | Televison & Video
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Tv wont turn on
Is the outlet powered? Try turning set on with own power button? Remote power button? If still nada, then check to see if something is amiss with the power supply section of set. Look for bad caps and diodes.
Oct 07, 2015 | Emerson Used Original BLC320EM9 Remote...
Emerson TV won't turn on
Check your power strip or surge protector connections if that don't work then you might need to replace the wall outlet.
Aug 14, 2013 | Televison & Video
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
EMERSON-MODEL#VT911OA-W VERSION-C
If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
Aug 20, 2007 | Emerson EWF2704 TV
Emerson LF320EM4 32" 720p 60Hz Class LED HDTV 23871273 Logo
667 people viewed this question
Top Emerson Computers & Internet Experts
Stan Skaggs
Stan Skaggs
ray gallant
FireballXL55
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
