Question about Measuring Tools & Sensors
MONITOR LOCKS ON 0 - Measuring Tools & Sensors
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
When I disconnect my IBM ThinkPad R50e from an external monitor, the text on the laptop is wacky. How do I fix this?
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Jul 11, 2012 | IBM ThinkPad Computers & Internet
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Philips 170S LCD - OSD locked and unable to remove display from screen, unable to adjust. Locked on Brightness setting which continually drops to 0. Any thoughts on how to fix?
It kind of sounds like one ore more of the buttons are stuck. Any chance something got spilt on them? Try pushing all the buttons repeatedly to see if any feel different or stuck.
Jul 01, 2009 | Philips 170S7FS 17" LCD Monitor
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dual monitor, Intel 82915G, ATI Rage 128 card, FC6
the ati chip is not so good dual monitor so please use nvidia for dual monitoring
Jan 09, 2009 | HP ATI FireGL4 (128 MB) Graphic Card
Top left side of the monitor asking for a key dats monitor locking so i need to open the lock plesae help me
Try holding the menu button down, this works for most monitors, just hold it down for at least 1 minute or so
Mar 16, 2007 | Thomson 20LCDB03B 20 in. Television
Measuring Tools & Sensors Logo
90 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
