Question about Top-O-Matic Topomatic Cigarette Rolling Machine Top-o-Matic
Why is the machine tearing an not filling the tubes?
  • 31 Answers
Filling the machine too much and/or packing too tight
Posted on May 09, 2016
Washing machine fills slow
If faucet is full opne, probebly are clogged filters Remove inle tubes and in the connection of tubes with machine youll find those filers. Remove them carfiully, wash them, reinsert and screw the tubes back.
How To Clean Your Washing Machine Filter
Oct 07, 2015 | Whirlpool Washing Machines
I am getting a d5 error on my samsung front load washer
One common error with these machines Is that the water level sensor pipework has a small hole. The pipe is connected to the drum, and as the unit rotates it will cause the rubber tubing to be degraded. If a small tear appears it will cause the sensor to malfunction - when there is no negative pressure as the water drains (or vacuum) it assumes the water is still there/. Either find the tear and repair with bicyle repair kit, or if the tear is near to the sensor connector - cut off and reattach slightly shorter tube.
Nov 19, 2013 | Samsung WF328AA Front Load Washer
Washer leaking from bottom when first turned on and tub filling, already checked inlet valves/tubes in back-no problems. Already drained filter and filter tube, did not resolve
Did you check your bellows for tears.That is the rubber that attaches tub to front of washer. the part that the door closes on. check in and around for tears in it ...Good luck if i helped you please vote ..thank you
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Kenmore washer mode
thas exactly correctits amotor coupling part number 285753A, probalby $25 and you can find complete tear down of unt on you tube
Dec 08, 2008 | Washing Machines
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Maytag pav51584ww
check the tube leading away from the fill level switch for splits .take tube offr and check for blockage. this tube goes to the air chamber which may also be clogged. if so clean it thoroughly
Apr 20, 2007 | Maytag PAV5158A Top Load Washer
Leaking from my MaytagPAV2300AWW
Had this problem. In my case the leak was comming from the fill indicator tube. It is a small tube running from the side of the tub to the control panel. Air pressure built up in this tube activates a pressure sensor that will shut off the fill valve at different levels depending on the pressure. The tube had become dry and cracked at the joint where it met the tub. I didn't discover the source of the problem unitl the hose actually tore loose and the thing overflowed. Remove this tube and inspect it and I bet you will find a small crack or tear.
Jan 15, 2007 | Maytag PAV2300 Top Load Washer
Top-O-Matic Topomatic Cigarette Rolling Machine Top-o-Matic Logo
88 people viewed this question
Top Top-O-Matic Cooking Experts
Tom Chichester
ray gallant
Are you a Top-O-Matic Cooking Expert? Answer questions, earn points and help others
