Question about Saeco Magic De Luxe Espresso Machine
Hi, the water flashlight is blinking. Water is full, machine is drainaged and problem is still. Please, help me.
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
The clothes are still water logged at the end of the cycle. I do not think it is a drainage problem for there is no pooled water.
Check for a kinked drain hose. Don't move the washer just look behind it with a flashlight
This happens a lot
If you move the washer tho the kink will straighten out and you will never see it.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 05, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a may tag epicz washing machine that continuously has the F20 eerier signal. We checked the hoses, drainage and filter. There is plenty of water, in fact the cloz are drenched dripping wet when...
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Aug 23, 2010 | Maytag EPIC MFW9700S Front Load Washer
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
Fault light are blinking
HI, there may be a clog in the drainage assembly. check all corresponding hoses and pump as well. if the hoses are clear of debris, this may confirm a pump malfunction. replace the pump in this case.
Also, check the inlet water valve assembly as well for non responding valves. replace the valve if needed.
Jul 21, 2009 | Washing Machines
Danby add water cycle, water being pumped out.
The pump acts as the drain valve. It sounds like the pump check valve is not working and you will probably have to replace the entire pump. The pump is fairly easy to replace.
Verify that the outlet from the pump goes directly to the drain hose. If so, the only other thing you can do is remove the drain pump and disassemble it to see if something is stuck in there or something. However, this is a more advanced procedure so I would recommend against it. Replace the pump.
Sep 12, 2008 | Danby DWM99W Top Load Washer
Air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Jun 15, 2007 | Sharp CV-P09FX Air Conditioner
Saeco Magic De Luxe Espresso Machine Logo
96 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
