Hiya, I have an Isis tv, brought last year, and it suddenly wont turn on neither is the led light but can still hear standby noise (all tvs do it) I need help fast cant afford another tv! Thanks x
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
SOURCE: samsung s42sd-yd01 plasma television wont power up
i have also this problem 1 relay klikt than must klikt the second relay it do nothing
i see a few elco,s on the visibel boards who are dik the plastik is dik not the metal
to hot maybe
can this give the problems
somewone a solution for this tv ??
sorry for my bad englis
thanks
Posted on Aug 13, 2008
SOURCE: Samsung LE40R73BD Will not switch on
I found a fix for this problem on another forum, It's caused by some blown capacitors on the main power board. I have a link to the original post, with step by step pictures for replacing the blown capacitors but don't know if it's ok to post it here. The repair cost me £7.49 for 5 capacitors RS part number 526-1109 and about £4.50 of that was for next day postage. I did the job myself in about 15 minutes and I have no experience with a soldering iron (i even had to borrow one). I replaced 3 capacitors, 2 of which looked blown and one which just looked swollen.
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the centre of the caps.
For a few quid I'm sure you could get someone else to do the soldering if you lack confidence.
The original post also linked to a supplier of the main power board for £130. I didn't mind having a go myself because I figured if I fouled up I could always just buy the board.
Posted on Apr 15, 2009
SOURCE: MY ILO LCT27HA36 TV won't come on, it just stays in standby mode/
I had the same problem. Then it worked for a while with me unplugging it and plugging it back in. Then one day it bit the dust. Nothing but the red light.
I found the solution on this website and I am trying to find it to thank the guy who posted it. For less than 10 bucks at Radio Shack, I was able to fix the problem with his instructions. And I know little to nothing about electronics. What it boils down to is this:
1. Lay the TV face down on something soft.
2. Take out the gazillion screws in the back until the back panel(s) come off.
3. Where the power cord plugs in, there is a ground wire going to a screw and another plug that you can undo. On this circuit board lies the problem.
4. Remove the circuit board (there are several other plugs on it. They all fit only one way, so I didn't pay much attention to how they came off.
5. Look on the board at the light blue cylindrical shaped capacitors. I don't remember how many there are, but look at the top of them. Find any that are bulging slightly at the top. They should be easy to spot. I had six on mine that were bulging. If you are handy with a soldering iron, remove the bad ones, making sure where each one comes from. There are a couple of different types/sizes. It is written on the side of each the resistance and what I assume is the voltage.
6. Go to the local Radio Shack and purchase new resistors. Note: I had some that were 1000 um and 36v or something and some that were 440 um and 16v. I couldn't find an exact match on one of those, but according to who I got my instructions from, as long as the resistance (um) number is the same, you can go up in the volts. So I ended up replacing some that were 16v with like 35v but the resistance (um) was the same and there are no problems.
7. Solder them carefully back into place. The circuit board is clear about which hole is positive (+) so don't get them backwards. The ones I bought from Radio Shack had a stripe on the side that was negative.
8. Put it all back together, and there ya have it.
Cheap fix. I admit I was darn skeptical it would work. I had already bought a new tv, but decided I wouldn't be out much if it didn't work. But it is working like the day I bought it again. And, it has a better picture than the Philips LCD tv that I bought to replace it.
Wish I could find the guy I got that info from. I was very impressed and grateful.
Hope this works for someone.
Posted on May 26, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
Led tv no picture
Sounds like fluorescent tube has gone, but you say this is LED? Newer tvs are LED. What you have, may be LCD, in which fluorescent tubes were used. You have no recourse.
Feb 12, 2014 | Televison & Video
Bush hd tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 03, 2014 | Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Hi i have an isis tv and have lost the manual to it. I can not get the tv to switch on, every time i turn the power on and try and use the remote to turn it on nothing happens and the led red light on the...
Hi can anyone please help me a have a isis tv only a year old was working fine last night aye want to put it on tonight and the red light flashes for a bit than comes on but no sound or picture what could it be the scream is just dark
Sep 13, 2011 | Televison & Video
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
