Question about Karcher K4600T200
How can I get the detergent to draw into water stream. Maybe I am missing on its operation. Can you help.
    Top Expert:
  • Karcher Master
  • 49,994 Answers
To get detergent into the wash you have to have no pressure in the wand
it doesn't wash with detergent at pressure
Posted on Jul 05, 2015
2 Suggested Answers
aroostookb
  • 98 Answers
SOURCE: Karcher detergent draw problem
return it to Walmart
Posted on Jun 23, 2009
Troy bilt pressure washer 020207 won't draw soap
Below is a list of the MOST COMMONLY reported troubleshooting issues.
you might want to try these steps:
No detergent
Reservoir is empty
Add more detergent
No detergent
Detergent suction tube not properly connected to the machine
Check connection
No detergent
Detergent is too thick Dilute detergent
No detergent
Filter on detergent suction tube is closed
Open the filter by turning it to the desired detergent intake
No detergent
Filter on detergent suction tube is clogged
Run warm water through filter to remove debris
No detergent
Damaged or clogged detergent suction tube
Remove obstruction or replace detergent suction tube
No detergent
Spray wand is in high pressure position
Turn spray wand tip to low pressure position
No detergent
Discharge nozzle is obstructed Blow out or remove debris with a fine needle
reference from:
http://troybilt.custhelp.com/app/answers/detail/a_id/10652/~/basic-troubleshooting---pressure-washers-%28gasoline-powered%29
please consult the operators manual you can get from link below:
Parts Manual Finder
or a Professional Shop Manual for model specific technical information.
If professional service is needed, please utilize the Authorized Service Center Directory to have the equipment professionally inspected and serviced.
You may also contact our Customer Technical Support department at:
Toll-Free Sales and Support (U.S.A. Only) 800.828.5500
Hours of Operation (EST)
Monday-Friday: 8:00am - 8:00pm
Saturdays: 9:00am - 8:00pm
Sundays: 10:00am-6:00pm
May 11, 2014 | Comet BXD2527 Pressure Washer Pump
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Detergent tank will not draw.
Detergent tanks will only draw at low pressure. Switching to low-pressure is done is several different ways with different makes/models. Some pressure nozzles are push/pull, some are twist and some just have a quick coupling and you have to keep up with a low pressure tip (usually colored black).
If it will not draw at low presser, it is either stopped up with debres, or the check ball inside the injector is stuck. The injector is the little device that is just before the outlet where the pressure hose hooks up. These always have a small metal ball, held in place with a tiny spring. This ball is there to prevent pressurized water from shooting back into the detergent tank. The ball and seat that it presses against can get stuck together with old detergent residues, calcified deposits from the water or even rust.
Use a small crescent wrench to take it apart -- or if you prefer, find the right size box end/open end (metric) wrench. Be very cautious as it comes apart because that little spring can leap out and they are hard to find.
I hope this is helpful to you. If it is, please take a sec to rate me. Thanks!
Don
Mar 10, 2012 | Karcher K 391m Pressure Washer
Control locked light on no buttons work
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pressure washer will not draw soap from cleaning tank
I had similiar problem, be sure the detergent hose isn't clogged. Mine was clogged where the clear detergent hose entered the pump. I cleared the clog and it worked perfectly
Apr 04, 2009 | Garden
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Karcher K4600T200 Logo
279 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
