Question about HP DesignJet 800ps InkJet Printer
Error 05:09 in HP Designjet 800ps, what to do?
My HP Designjet 800ps gives the error 05:09, I consulted the service manual and says the following: "If this Error Code Appears on the DesignJet 800 Series Printer, Then the model number configured in the Printer is incorrect (the Printer thinks it's a DesignJet 500 Series Printer). In this case reconfigure the model number." The problem is that is only possible introduce the serial number and I'm already input it a million times and nothing. Every time I restart the printer it gives the same error. Could someone please help me?
    Scholar:
  • HP Expert
  • 123 Answers
Hi. This type of problem often happens when the electronics module or the ink supply station is replaced. The plotter ID is kept in both locations and when one is replaced, the plotter asks which was changed. If the questions is answered wrongly, the machine assumes the wrong identity. Is that what happened to your machine? If so, there is a fix, but not an easy one. If you still need some help with this, call me at 800-959-1575
Posted on Jun 07, 2016
  • HP Master
  • 1,915 Answers
I assume if you have the service manual it means you are going into the correct eeprom area to setup the model. It is possible that the HPGL portion of the card has failed, or the hardrive is bad.
Posted on Apr 18, 2015
3 Suggested Answers
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Posted on Jul 06, 2011
Hello. My HP Designjet 800ps says "too little ink to prepare the ink system". I want to know if there is something that i can do to erase this error.
It sounds like the printer has been set to initialize as if new and thinks that there is no ink in the tubes so it wants to do a full prime. Other than replacing the carts and letting it run I am not sure there is another way.
Apr 07, 2015 | HP DesignJet 800ps InkJet Printer
SYSTEM ERROR 20:10
Error Code 20:10 does not appear to be a valid code. Could you verify that is what is being displayed? What is the plotter doing when the error occurs?
Oct 03, 2013 | HP DesignJet 800ps (24 in.) InkJet Printer
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
Jul 05, 2011 | HP DesignJet 800ps InkJet Printer
Plotter will not print
I solved issue. It would cost a fee for me to give the solution. You know how it is? Thanks for the.......... well thanks
Mar 25, 2010 | HP DesignJet 800ps InkJet Printer
My HP 800ps designjet is making a constant clicking noise near the ps card and will not print. I've tried everything from reloading driver & firmware to checking print heads and settings. Nothing seems...
Sounds like your power supply bit the dust. The power supply on this printer is similar to a PC power supply in appearcnace and is pretty easy to replace. You can download the service manual and take a look at the procedure if you are inclined to do the repair yourself or have someone do it for you. www.lpscomputer.com/ec/manuals.htm
The part can be purchased here: http://www.lpscomputer.com/c-643-designjet-500-510-800.aspx
Dec 07, 2009 | HP DesignJet 800ps (24 in.) InkJet Printer
HP DesignJet 800PS resets everytime I send it a job
try removing the jetdirect card and sending something direct via the usb port. if this doesn't work then you may have an issue with the main pca.
Aug 15, 2009 | HP DesignJet 800ps InkJet Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
try processing the file in the PC instead
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
HP DesignJet 800ps InkJet Printer Logo
182 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
