Question about Philips DVDR3440H DVD Recorder/HDD Recorder
Why that cam1 and cam2 in dvdr3440h if video camera is connect the picture did not show on the TV. but the DV IN the cable is not found when the put on power DV is on recorder screen
    Master:
  • Philips Master
  • 487 Answers
Try Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Posted on May 05, 2015
4 Suggested Answers
  • 8 Answers
SOURCE: I have a/v connections on my tv. In order to
hook up your tv output to your vcr in put or if you have a cable jack you can hook your cable to your vcr input and the out to your tv you will either have to change the channel to3 or4 or change the tv video input
Posted on Mar 01, 2009
  • 44 Answers
SOURCE: Coaxial cord won't fit on VCR/DVD
TV-Video | DVD-TV
Posted on Jul 08, 2009
  • 601 Answers
SOURCE: cannot get dvd to move
Is the camera switched on when you are switching to CAM1?
Some units won;t switch to an input if there isn't anything going through it...
Posted on Dec 12, 2011
I set up my camera cd driver(panasonic nv-ds65) on my pc and then connected cable to camera (dv slot) and pc(usb) ,and couldnot download movie(on the type) to pc ,but i could download pictures to pc by...
you just need cable with both end DV pin.its mean one end you have dv out put then where you input also need DV in put so need both side DV pins.after that you can download your movie on pc.
Oct 23, 2010 | Panasonic NV-DS65 Mini DV Digital...
Connect to tv problem
The cable you describe should be the only cable that you need. You want to make sure that you switch to whichever input you connect to on your TV. If you are getting sound but no picture there may be a problem with either the input or your cable. Connect the cable to a different input to see if it works. If it does then the problem is with the input on your TV. If it doesn't work then there is something wrong with the cable. You may have to get it replaced at the place you purchased the camera from/
May 29, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Viewing pictures on my t.v from my camera.
well. when you bought the camera. they gave you some cables for sure. well you should have a cable which has at one end the usb and at the other end should be split into two or three one yelow one white and one red. the tv has the same colors you put the same colors together and that's it
Mar 12, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
Will not put video on the computer when I use the usb cable
You need to install picture package software cd supplied with camcorder, in PC and use iLink / DV port (IEEE1394) hook up to transfer video files in PC.
User manual has details about transfer files in PC procedure.
Jan 08, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Panasonic PV-GX31 DV Camcorder - Need Help!!
I can't find any reference to a PV-GX31 model, BUT if your camcorder is a PV-GS31 MiniDV model, then you need special software for it to show up on your computer screen. Panasonic supply the software to show and edit still shots (through your USB cable). But if you want to show and edit movies, then you need a firewire cable, a firewire connection on your computer to connect it to, and most importantly some editing software. PCs are pretty slack in this area, so you should use a mac!
Sep 02, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Showing my video on TV from my JVC GR-DVL210A
Most places that sell cameras will probably also sell the cable that allows you to connect your camera to the TV. Depending on your camera, one end of the cable plugs into the camera and the other end probably has the Yellow, Red, White plugs that will plug into your TV.
You might also check the camera company website to see if they sell accessories specific to your camera.
Aug 11, 2008 | JVC GR-DVL210A Mini DV Digital Camcorder
Connecting to my tv
A-V cable will be like below picture having 3 RCA pins Yellow Red & White colors.
Jul 11, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Can't view movies on TV
You should purchase A-V Connecting Cable to connect Camera with TV. Its common available cable and picture is pasted here.
May 31, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
GR-D250 DV Cable
connect a tv card on your computer then try because this model is not supporting through usb or dv
Oct 22, 2007 | JVC GR-X5 Mini DV Digital Camcorder
Philips DVDR3440H DVD Recorder/HDD Recorder Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
