Question about Hotpoint Washing Machines
HOTPOINT AQUARIOUS 1100 WASHER DRYE Hi When I shut the door the washing machine does not kick in and start washing as if it does not have any power or it's not registering that the door has been shut.
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Replace door inter lock
Posted on Apr 12, 2015
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
  • 27 Answers
SOURCE: HOTPOINT aquarious extra
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Posted on Feb 22, 2008
barkencoa
  • 3463 Answers
SOURCE: operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Posted on Jan 29, 2009
  • 53 Answers
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Posted on Oct 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 19, 2010
Hotpoint aquarious making loud gring noises and sometimes does't start
sounds like motor brushes. physically check your motor for black power, that's a sure sign of brush wear. could be seized bearings, try spin the barrel of the washer by hand, if it's stuck/very hard to turn, thats a sure sign of bearing seizure.
Nov 10, 2013 | Hotpoint Washing Machines
No power to hotpoint aquarious 1000 after changing door hinge
First check the wall outlet has the correct voltage supply, if it is having the proper voltage.
It sounds like when you changed the door hinge on the door lock system is getting failed, and it damages the timer. Since the timer is damaged there is no power available to the washer.
Other possibilities are the failure is either the control board, power cord or a loose or bad connection between the power cord and the control board.
However, you need technician's help to diagnosis the problem related to controlling board.
Hope this helps.
Shane
Feb 12, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Operating instructions
Hello.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
