Question about Electrical Supplies
Milky oil in onan marquiss 7000 generator air cleaner. What is the cause
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
machinehead2
  • 14 Answers
SOURCE: can i use synthetic oil in my new onan 6500 portable generator
Johndeere 10w-30 in cooler weather and 5w30 in warmer weather. Any auto parts store has small engine oil. They may have a better idea when you go to purchase your oil for your particular climate.
Posted on Jan 10, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
mamicheddy
  • 79 Answers
SOURCE: Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Posted on May 09, 2009
Valve adjustment for onan 7000 generator
What is your question specifically? how to adjust them? how to turn the engine over? Be more specific
Aug 26, 2014 | Onan Cummins 7.0 HGJAB-6756 RV QG 7000...
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
My Onan Marques Generator runs but not swap over to 120 volts
What do you mean won't swap over to 120Volts? are you referring to a transfer switch not switching over to generator?
Dec 17, 2012 | Onan Marquis RV Generator 7000 Watts Gas
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Generator does not start, how do I fix it
It could not be starting for any number of reasons. Old stale fuel, carbeurator out of adjustment, bad spark plug, dirty air cleaner.
Apr 30, 2012 | Watts Onan Portable Generator - 4000 ,...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
