My door will not open
Done cycle and wont open
  • 101 Answers
All washers have a time delay on the door lock, sometimes this unit burns out. Most washers have a cord to pull to unlock the front door this is usually accessible by taking the top panel off & searching for the cord.
Posted on Apr 08, 2015
Wont open after cycle is done door & # mw8107wa
depends on make and model neither of which you have shared with us , none are auto opening tho either have a handle to pull or a large tab to push in on near bottom of control panel
Feb 02, 2015 | Microwave Ovens
Lights on panel butwont start
we have had one for many years. it works great. we have had to replace our panel 2 times. I read up on this and they say to leave the door open after it is done the wash so all the humidity can disapate. we dont use the heated dry cycle anymore and just crack the door open after it is done.
Sep 02, 2014 | Kenmore Dishwashers
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
My machine has stopped half way through the cycle, hasn't rinsed or had it's final spin and says DOOR on the display. The door is properly closed and now wont go on ant other program or fill up with...
Try a reset of the washers' operating sytem by unplugging it, waiting a few minutes and then plugging it back in. It may restart the cycle all over or it may do nothing and allow you toopen the door. If you do finish the cycle and/or get the door open, check the seal thouroughly to make sure there is no debris and/or coins in the seal. It would be a good time to clean the seal as well with hot water and a soft cloth if you have not done so recently.
Let me know if this works. If it does not , please let us know the make and model of your machine.
Dec 19, 2010 | Washing Machines
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Door wont unlock
Try "end of cycle" button, & wait for a couple of minutes before u try the door; do not force door.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Try first to unplug the power cable. In case it will not help,you have to raise the top of the washer to get to the switch (near the door)and try to open it manually. If the problem will return,you should replace the switch. Good luck!
Oct 01, 2006 | Ariston Technologies AWD120WH Ariston
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
