Photography Logo
B
Barry Rodgers Posted on Apr 08, 2015
Need a replacement handle and vertical clamp unit
Rest of unit is good
Sub zero 690 side by side
Behind the panel and the control unit are light bulbs, They made need to be replaces. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2answers
Big black circle spot appears on the upper left side of the lcd
It seems your screen is bleeding. If it is not acceptable, then you can replace this screen.
My engine was idleing rough breaks felt hard and found vacum line disconnected when i re connnected the line engine smoothed out and brakes seemed ok but line went flat and i did not see any kind of clamp...
shouldnt need a clamp... if your hose sucks flat thats a good sign its time for replacing...you might also want to check the rest of your hoses...
3answers
Need replacement table clamp for pasta maker
Have you tried going to the manufacturer's website? I have this pasta maker on my website and you might try one of the links. But you will probably have to get a new machine. You could also go to your hardware store. They might have a clamp that you could use. Good luck.
1helpful
2answers
I need to take a power window motor out of my 2001 chevy silverado 2500 but dont know how
You need to replace the " regulator". this includes the motor, cables and pulleys ect. $80-100. Open door, remove door panel, cut the clear plastic around the door handle, loosen the 2 clamps on the top vertical travel rails that clamp to the window, (this is all part of the regulator) . somehow you need hold the window up, (I use a towel, 2 pieces of wood and a big clamp) now the window glass can be released from the clamps on the regulator. unbolt the regulator mechanism and replace. should take an hour or less the first time. about 10-15 minute thereafter. bc
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
6helpful
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Sep 06, 2009 • Garden
2helpful
2answers
I own a 1994 honda accord and the window pane jams and goes off alignment when I winding it up,atimes it will stop working and cant wind up. How do I fix it?
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.Then you need to pull off the weather seal to get to the inside of the door. It sounds like the guide rails for the window have come loose
How do you change headlights on a 2006 trailblazer ls?
first remove the headlamp assembly. there should be one or two clamps with a rubber grip vertically inserted behind the headlamp. they can be difficult but you just pull them up to remove the assembly. Then the socket should have either a snap in or twist in retention system remove it and you can pull the bulb. when you replace the new one be sure not to handle it with your hands. use a clean cloth, glove, or other item to insert it and then reverse the procedure to install the rest.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Photography Expert? Answer questions, earn points and help others
