Question about Whirlpool Refrigerators
Alternative powerstart relays for my whirlpool gold side by side fridge
  • Whirlpool Master
  • 5,323 Answers
U MEAN 3 IN 1 HARDSTART KIT
Posted on Apr 10, 2015
  • 184 Answers
SOURCE: BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Posted on Apr 08, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
mamapie
  • 5 Answers
SOURCE: whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Posted on Oct 16, 2008
  • 71 Answers
SOURCE: Removing Doors on Whirlpool Gold GS6NHAXVQ side by side fridge
remove the kick plate (lower grill) on the freeezer hinge is a tube folow that tube to a disconect, unscew the nut then remove the nut from the tube then remove the top hinge and lift the door off the lower hinge threading the tube through the lower hinge.
Posted on Dec 24, 2008
woodchuck789
  • 4070 Answers
SOURCE: whirlpool gold side by side is thawing out and won't stay cold
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 27, 2009
Where can i find a wiring diagram for whirlpool control board w10135090?
Normally unit technical sheet is hidden for technician reference inside the front bottom kick plate or just under it. Please put it back after using it to the right place. Next guy working on your fridge need to refer that.
Sep 03, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Lights in fridge side are all out. After changing bulbs, sounds like a relay sticking and will knock out all lights in fridge unless we loosen off the bulbs in the fridge side
your main control board Part#4334000 is defective in lower left rear of unit remove it from the white plastic box and underneath it will have a burned spot on the printed circuit trace get it at appliance parts pros 1-877-477-7278
Sep 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My fridge stoped cooling
Sounds like you are describing a capacitor. And the relay that is attached to the compressor is called a PTC relay.
Jan 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need to unplug fridge- Whirlpool Gold Side-by-Side
you will have at least a foot of flexable water hose. Pull it out slowly to make sure its not tangled.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side freezer not freezing but fridge is running
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
